So confused, Alumilite question
chartle
Pgh, PA
Thought I had this all figured out but ..........
What is the difference between:
  • Amazing Clear Cast
  • Alumilite Clear
  • Alumilite Water Clear
I've gone through a quart and a half of PR and want to try something else. I can get Amazing Clear Cast locally to start.
Big issue does Amazing Clear Cast need pressure and how does it turn?
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
Amazing Clear Cast is an epoxy resin that can be used for casting but is best used as a bar top finish. It is much softer and is NOT good for our kind of casting in my opinion. Water Clear and Clear is a urethane resin. Water Clear is also softer and is not the best for our application. Clear was formulated specifically for our type of casting and is the best choice, IMO.
