Silly question on terms
Linarestribe
Mount Vernon, WA
I need some help with casting lingo. When I read "urethane resin" is that the same as poly resin? Does alumilite fell into this category?
Jorge
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
Jorge,
Urethane resin and poly resin are not the same. Urethane resin is typically a 2 part system. Alumilite is a urethane resin. Poly resin is polyester resin such as Silmar 41 or Castin Craft. It is the same type of resin frequently used for fiberglass work and uses a base resin with a catalyst added before casting.
