Scale to .1 gram
CrashmanS
West Virginia
I need a scale that will weight down to .1 of gram. Model numbers or links would be appreciated. Thanks.
Sent from my SM-N920P using Tapatalk
Skie_M
Lawton, Ok
Hmmm .... my little digital scale from Harbor Freight will display down to tenths of a gram, but it's not perfectly accurate ... it can be off by .1 grams, so I typically need to make sure that I am weighing 10 times as much to get an accurate reading.
Make sure that if you need .1 gram accuracy, your scale goes to .01 grams with +/- .02 grams accuracy or better.
By the way, 1 karot weight (ct) in precious stones comes out to .2 grams ... why are you needing this level of accuracy?
CrashmanS
West Virginia
The one I have now is down to the single gram. One large pours I'm ok. But I'm doing some smaller stuff and it just won't get the proper mix ratio correct.
