Questions about vacuum pump and stabilization
Thud 54963
Oshkosh WI
I have a 2 stage 3 cfm vacuum pump. It pulls a vacuum of about -27 mmHg.
I will typically run the vacuum about 24 to 36 hours to get to a point where I have no bubbles. I usually stabilize buckeye or maple burl. Is this typical of the length of time it takes others?
Also, because of my anal retentive nature I turn the pump off at night. Am I being overly cautious?
Thanks in advance for your help.
KenV
Juneau, Alaska.
If you are turning the pump off and on, the vacuum is probably not maintained for 24 to 36 hours. I let mine run over night, ispecially if I start a batch later in the day.
Other than that, reads as similar to what I do.
Rifleman1776
Mountain Home, Arkansas, USA.
I pull only 23 inches and for about 30 min. to an hour. Get good results with most woods. But, buckeye seems to me a possibly difficult wood to stable. A few woods I will not try. Those include anything in the rosewood family, Osage Orange, Red Cedar and/or other exceptionally hard or oily woods. Most wouldn't benefit anyway.
Dieseldoc
Livermore, Ca 94550
vac chamber
With my vac pot will hold vac for 24 hours with out having to keep pump on. I start out running it until the bobbles are gone which is about one - two hours with maple, oak, walnut any other punkie wood.
Vac pressure is 29 and after 24 hours it still 29-mmHG. I have even restarted the pump and gauge will stay the same with out pump on or off. I believe there may be a leak in the system that caused lost of vac.
I have found one of the major leak item is the shut off valve, as some pot have cheap ball valves, I changed my uot before using it the first time.
