Pressure vs. Vacuum - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 12-04-2018, 01:16 PM   #1 (permalink)
Photos: 0
Default Pressure vs. Vacuum
I am thinking about making a pressure pot for casting. What is the difference between using vacuum or pressure? Is one better than the other? The pot would be used for hopefully bubble free casting.
Thanks for any input.
kenlholley is online now   Reply With Quote Top
Old 12-04-2018, 01:47 PM   #2 (permalink)
More4dan's Avatar
Photos: 5
Default
Vacuum is used for stabilizing wood. Pressure for bubble ďfreeĒ casting. Vacuum can be used to degas the resin before pouring IF you have enough working time.
More4dan is online now   Reply With Quote Top
Old 12-04-2018, 01:48 PM   #3 (permalink)
magpens's Avatar
Photos: 75
Default
Just tagging along to learn more about this subject.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is online now   Reply With Quote Top
Advertisement
Old 12-04-2018, 01:52 PM   #4 (permalink)
chartle's Avatar
Photos: 0
Default
I saved this for just this question.
https://www.youtube.com/watch?v=ShSxUg4Yyws
But its like asking which is better for building furniture hammers or saws.
__________________
Cliff
RKB
chartle is offline   Reply With Quote Top
Old 12-04-2018, 02:01 PM   #5 (permalink)
Photos: 0
Default
You have to use pressure to reliably eliminate bubbles. Degassing/ vacuuming works well to get rid of most of the bubbles but it may not be feasible to do this effectively with short pot life resins. I don't bother with vacuum degassing anymore even though my resin has a 40 working time, I strictly use pressure now.
jcjc is offline   Reply With Quote Top
Old 12-04-2018, 02:04 PM   #6 (permalink)
chartle's Avatar
Photos: 0
Default
Its also my understanding that resins like Alumilite create gas as they cure and the pressure keeps the gas in solution.
__________________
Cliff
Old 12-04-2018, 02:15 PM   #7 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
FYI, while some may caution you about using the HF Pots, I use the HF pot for both pressure and vacuum. They are not too difficult to configure to use both ways on a single pot.
The cautions on HF pressure pots is that they (some) do not to handle higher pressures past 50 PSI 100% reliably, and there are always the folks that think that they are the best judges of what is acceptable and end up destroying something or maiming themselves and blaming others. I have been using HF pressure pots for about 12 years now and have not had a problem. I do not exceed the limits recommended.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is online now   Reply With Quote Top
Old 12-04-2018, 05:15 PM   #8 (permalink)
Photos: 0
Default
Quote:
not saying this isnít true but Iíve never used or heard of a resin that creates gas as it cures. that to me is a serious design flaw for several reasons.
Old 12-04-2018, 09:13 PM   #9 (permalink)
TattooedTurner's Avatar
Photos: 271
Default
I never had any luck at all degassing resin with vacuum. In fact, I got far more bubbles with polyresin than I did without degassing. Like Hank, I too use a HF pressure pot without any worries. I put dry teflon lube on the gasket and it’s held 50psi for 3 days straight. I once forgot to turn the pressure down on my compressor after inflating my bike tires. The safety relief valve I put on mine goes off at 70psi and worked like a charm! No damage at all to the pot itself, but I highly recommend not going past 50psi just to be safe.
__________________
Jay
TattooedTurner is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
