Palmwood Stabilized?
RobS
Carlsbad, CA
Anyone try stabilizing palmwood with Cactus Juice? I love the look of it, but the last two I made, I had to really work at getting a proper multi coat of CA for a nice glass smooth finish. I was wondering if anyone tried stabilizing it and had an easier time preventing blowouts and reducing the amount of sanding and CA finish work. Don't get me wrong I'll spend 4 hrs on something to get it right, but if there is a smarter way, I'm up for it.
KenV
Juneau, Alaska.
Have done cactus juice on several pieces. I use a skew and am very careful to cut "down hill".
A bit easier but care is still needed.
Do you have some turned down that is not stabalized. Love to see what it looks like. Have to say I never work with it or even bamboo. Would love to see that in a turned down state also.
RobS
Carlsbad, CA
Cigar Pen, Palmwood, CA & friction finish, Gold Hardware, my 6th pen I have made.
The shape was intentional, the owner was a quarterback.
View in Gallery
Cigar Pen, Palmwood, CA & friction finish, Gunmetal Hardware, my 22nd pen I have made.
The thin shape was requested by the owner, he wanted the smallest largest pen shape, the owner is french and is accustomed to a S.T. Dupont.
View in Gallery
I normaly sand through 600grit with abranet, and then have to do 3-5 coats of thin and 2-5 coats of med, to fill in the voids. I use a square-radius carbide full sized handled cutter and turn the last bit at 3,000+ RPM holding the cutter at a 45 degree instead of horizontal to skim cut. I just suck at CA coating and was wondering if stabilizing would reduce the work effort. I end up applying a friction finish over the CA, because the CA fill the voids, but I end up sanding down everything else back to the wood.
Thanks Rob. Both look good. I love the grain of that wood. Will have to look into this in the future. Thanks for showing.:)
RobS
Carlsbad, CA
John
Quick tip if you can buy it in person, not all grain is the same, these had a very tight black spaghetti type pattern on the ends (as in it looked like I was holding a bunch of black noodles very tightly). However, I received another from an online order and the spacing between the black is huge, which I think will make for a poor grain pattern once turned.
John
Thanks for tip Rob. I try to buy only woods that I can see and touch but have bought some such as BOW without seeing and have been both happy and sad. Want to take a shot at bamboo also and I am betting that too has color differences and grain differences. Just something for a future project. Have a lot of those.:eek:
KenV
Juneau, Alaska.
John,
Go to the photos section and use the search function there to search on "palm". I saw pens with fan palm, black palm and red palm on a quick look.
Palm is harvested from the outside of the trunk and fiber density varies as you move to the core (less density towards the core).
Like turning a bundle of porcupine quills.
John,
Yes a little something different than the norm. That would make it intriguing:)
