Liquid Diamonds epoxy resin - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 09-17-2017, 08:41 PM   #21 (permalink)
Photos: 0
Default
I have not heard anything negative about it , its my next
Chiller Killer is offline   Reply With Quote Top
Old 09-18-2017, 10:03 AM   #22 (permalink)
triw51's Avatar
Photos: 0
Default
can you color the resin (i.e. blue, white etc.)? If so what would you use to dye the resin? Thanks William
__________________
ZIP IT Please
Western Creations Forge and Woodworking
Isaiah 58:6
triw51 is online now   Reply With Quote Top
Old 09-18-2017, 10:45 AM   #23 (permalink)
tkbarron's Avatar
Photos: 0
Default
Quote:
I've used both dye and mica with great results. Because of the long pot life, I'd recommend holding off pouring your mica casts as soon as you mix in the hardener because mica tends to settle. Give it about 30 minutes then stir the contents again before pouring.
Just my $.02.
Thanks!
tkbarron is offline   Reply With Quote Top
Advertisement
Old 09-19-2017, 07:06 AM   #24 (permalink)
Photos: 60
Default
I did some research last night and found the Technical Data Sheet on the TurnersWarehouse web site.
It stated that Liquid Diamond will enter the gel state in about 45 minutes if you are working in a room that is 77 degrees Fahrenheit.
As far as tinting goes, I am using my alumilite dyes with no issues. I know of people who are using Transtint dyes, and some who are using Mixol dyes.
I have not tried Mixol dyes with Liquid Diamond yet, however, I have used them to tint 5 minute epoxy with good results.
One thing I will say for sure, is if you remove the cast pieces from you molds to soon they can stick to whatever you lay them on and they can deform under their own weight.
eharri446 is online now   Reply With Quote Top
Old 09-19-2017, 07:32 AM   #25 (permalink)
Photos: 0
Default
Does LD get as hard as acrylic? Hard enough that you can not dent it with a fingernail?
PatrickR is offline   Reply With Quote Top
Old 09-19-2017, 08:15 AM   #26 (permalink)
BeeAMaker's Avatar
Photos: 0
Default
Quote:
After about 72 hours it is very hard, at least comparable to acrylic and you can not dent it with your finger nail. Within that first 24 hours however it is very soft and as mentioned it can deform under it's own weight. I have had that happen to me once, being to impatient.
__________________
When you speak, you repeat what you already know. When you listen you learn...
Get the Pressure Pot Caddy!
Vertical Casting System
The MakerHive
BeeAMaker is offline   Reply With Quote Top
Old 09-19-2017, 08:21 AM   #27 (permalink)
Photos: 0
Default
Thanks! I just need to wait longer then. I completed my first two sets of castings over the last two days. Just 24 hrs since the last one.
Old 09-19-2017, 08:39 AM   #28 (permalink)
BeeAMaker's Avatar
Photos: 0
Default
I now wait 3 days before turning.
__________________
The MakerHive
Old 09-19-2017, 09:27 AM   #29 (permalink)
Photos: 60
Default
The technical data sheet said that it could take as long as 7 days to reach maximum hardness if left in a room at about 50 degrees Fahrenheit, or maybe it was 77 degrees. It is terrible what happens to your mind as you get older.
I have four blanks and one tube that I cast and it was fairly hard after 36 hours. I have not tried to turn it yet, too many other things going on.
Old 09-19-2017, 12:07 PM   #30 (permalink)
Spinzwood's Avatar
Photos: 0
Default
I've seen some comments, Not about LD, but other resins. Note, I'm a true noob at this.. so be kind :) The question I have has to do with wrapping items around the brass tube and casting only to find there is a 'bubble' interface between the item and the tube. Let's say snake skin or a feather.
So, the question is..other than pressure potting.. can this be done in a vacuum to suck all air out of that interface area? Sounds like the cure time is pretty long.
Spinzwood is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
