Liquid Diamonds Changing Mix Ratio - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 09-09-2018, 09:13 PM   #1 (permalink)
MRDucks2's Avatar
Photos: 0
Default Liquid Diamonds Changing Mix Ratio
From the previous items we posted under our Novice Trials of Liquid Diamonds, Chuck (dalecamino) and I did not like the long time required for LD blanks to actually cure hard enough to turn and polish.
We had learned that Aldax Enterprises a Liquid Diamonds vendor in New South Wales states on their website,
“This product can be mixed at a ratio of 65% hardener. This will create a super clear bubble free finish. Mixing by weight (100:65 resin/hardener). Your pieces will cure faster, harder, and have less bubbles than the 2-1 mixture. This mixing procedure is not recommended on large pieces above 2”.
So, with Chucks approval (since he brought the Liquid Diamonds to my shop) I decided to run a test and see how changing the mix ratio between parts A and B affected the cure of the blanks.
I picked 4 ratios, the original 2:1, 1.8:1, 1.7:1 and 1.54:1 to see what the result was.
One of each ratio was mixed and poured into each of the 4 voids of a 4 blank mold.
They were placed in a pot under 60psig and left for 22 hours (no reason for 22, that just happened to be when I got back to the shop. At that point they were removed from the pot and the mold. (Mold had been sprayed with Stoner Thermoset Epoxy Mold Release)
They all looked good and were pliable, which we know is normal for Liquid Diamonds out of the pot. I checked each with my 2.5 pound weight to see how much they would sag under the weight right out of the pot:
The standard 2:1 ratio
A ratio of 1.8:1
Ratio of 1.7:1
The ratio of 1.54:1
There was some difference between the 2.0:1 and 1.8:1 but you can see the greater difference at 1.7:1. With my crude methods, there didn’t seem to be a lot of difference between the 1.7:1 and the 1.54:1.
I think the biggest difference shows up a day later.
From fiddling around with the blanks, bending, squeezing, pinching, marking, it appears that for this test the 1.7:1 ratio produces in 24 hours out of the pot a blank that has very, very similar properties of the blank from the earlier test at 6 days out of the pot.
Here is that blank under the weight at 6 days for comparison:
Obviously results may vary based on your temperatures, humidity, etc. I think the key is that if you do like/want to use Liquid Diamonds and don’t want to wait “4 or 5 days” before it is completely cured, you can modify the ratio to increase the hardener and thereby decrease the cure time.
Doesn’t take much and see what works best for you.
- Happy Turning!
__________________
New Contest for 2019 BASH!
FINAL VOTE in what is considered the fairest, best balanced competition for all members:The PRETTY RESIN PEN CONTEST http://www.penturners.org/forum/f422...l-vote-158738/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 09-09-2018, 09:21 PM   #2 (permalink)
BRobbins629's Avatar
Photos: 49
Default
Nice experiment! Thanks
__________________
Bruce
BRobbins629 is offline   Reply With Quote Top
Old 09-09-2018, 09:45 PM   #3 (permalink)
EBorraga's Avatar
Photos: 78
Default
Mike, thats great info!! This should go in Library!
__________________
Wicked Chickens lay deviled Egg's
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is offline   Reply With Quote Top
Advertisement
Old 09-09-2018, 10:54 PM   #4 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Awesome Mike! You have much more ambition than I do. Well done. I am waiting for the original cast blanks to pass the nail test, and the mood hits me, before I turn anymore of them.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Old 09-09-2018, 10:56 PM   #5 (permalink)
magpens's Avatar
Photos: 75
Default
Thanks for sharing this with us .... very interesting !
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 09-10-2018, 09:34 AM   #6 (permalink)
Gregory Hardy's Avatar
Photos: 12
Default
This is fantastic information. (I especially like the "Official Cord Wood Test!") Your efforts are going to make my life easier - thanks for sharing.
__________________
Gregory Hardy
www.hardypens.com
Gregory Hardy is offline   Reply With Quote Top
Old 09-10-2018, 11:13 AM   #7 (permalink)
mark james's Avatar
Photos: 484
Default
"Seeing" often beats "Reading/Hearing."
Great process.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 09-10-2018, 11:33 AM   #8 (permalink)
Photos: 1
Default
I'd be interested in your impressions of how the higher ratio resin/hardener blanks turn and finish compared to the normal recommended mix. Harder? More/less/same brittleness? How it polishes et cetera. Thanks.
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is online now   Reply With Quote Top
Old 09-10-2018, 12:14 PM   #9 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Quote:
Thanks, Curly. That is a natural next step and will be coming up later in the week.
__________________
Be kind &
Old 09-11-2018, 07:17 AM   #10 (permalink)
edstreet's Avatar
Photos: 2
Default
Interesting results. However you do not need to change the ratio to improve cure times. It’s certainly viable to do that with the standard ratio mix.
__________________
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
