How to Stabilize a corn cob?
keithbyrd
Mount Wolf, PA
My son wants me to make a goose call blank for him out of corn cob. I need this to be 1 1/2' in diameter. So my question(s) is/are:
1. Do I stabilize the cob with cactus juice them put it in 1 1/2" mold and use silmar41 or alumilite in a pressure pot?
2. Just put it in silmar 41 or alumilite and a pressure pot or vacuum chamber?
3. Do 2 but use silmar since alumilite sets too quickly to be absorbed through the cob?
4. I missed it altogether and there is another way that you are willing to tell me about!
I need to get this done this week end since I will be driving to his house (10 hours away!) on Tuesday!
Any help you can give is greatly appreciated!
Dave Turner
Sylvania, Ohio
I've done several corn cob pens. After the cob is thoroughly dried and kernels removed, I cut it to the needed length and then saturate it with thin CA. Once hardened, I drill out the hole for the tube then saturate it again with more thin CA, both inside the hole and outside. I then re-drill the hole to make sure it will fit the tube and epoxy in the tube. After squaring the ends, I'll start turning it. I turn a little off and then add some more thin CA. I keep this up until I get to the finished diameter. I will then switch over to medium or thick CA to start building up layers until I get all the irregularities filled in. I use accelerator between each coat of CA. I then sand and polish like any CA coated pen.
This method runs through a lot of CA, but it's pretty quick and I've always gotten good results. I find the thinner the starting corncob, the better the surface pattern on the finished pen. This shouldn't be any problem for a 1 1/2" diameter goose call.
plantman
Green Bay, Wi
I use the same method as Dave on my corn cob pens. This works great on the smaller pen size blanks that have a tube inside to support them, however on a larger project of 1 1/2" with a thicker wall size and slip fit reed, you may need a better stabilizer than the CA. Jim S
KenV
Juneau, Alaska.
Keith. I have used stabilized corn cobs. I think they came from Tim McGill in Iowa.
Those were smaller cobs suitable for cigar pens.
Full sized cobs Wil be closer to 1 1/2 inches and some larger
I can see no reason not to use Cactus Juice and a large cob. Cobs dye easily.
SDB777
Cabot, Arkansas USA
With the duck call, I'd drill it under the 5/8" bore and then fill the hole with a 'filler'(as you are just going to drill that out while making the call anyway-why waste material)...then stabilize/cast.
Scott (duck are fun) B
