How to cast stamps? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 04-09-2019, 11:44 AM   #1 (permalink)
Photos: 25
Question How to cast stamps?
Greetings, all. I'm trying something new- putting used stamps on a pen. I have a number of precious stamps (and some practice ones!) from my philatelist friend. I intend to make the blanks (for a roller ball pen) and send them to be cast.
I'm not sure how to attach these posted stamps. Do I use something like modge podge? And should I be spraying on some kind of clear coat before sending it out to be cast in acrylic?
Any help would be appreciated!
Cheers
Katya
Katya is offline   Reply With Quote Top
Old 04-09-2019, 12:41 PM   #2 (permalink)
BSea's Avatar
Photos: 51
Default
I think you could use white glue to glue the stamps to the tube. I've never tried used stamps, so I don't know for sure. But I use modge podge over the stamps after they are attached.
Hope this helps.
__________________
Bob
Central Arkansas IAP Chapter Member
BSea is offline   Reply With Quote Top
Old 04-09-2019, 01:18 PM   #3 (permalink)
mecompco's Avatar
Photos: 10
Default
I've gotten decent results using water-diluted white glue to affix the stamps to the tube (use a small paint brush), then spraying with clear acrylic spray or Mod-Podge spray. I'd do a test first to make sure your PR (assuming that's what you're using--it's inexpensive and requires to pressure pot) doesn't eat your clear coat. It is a messy business, but well worth some experimentation.
__________________
Michael
Fairfield, Maine
mecompco is offline   Reply With Quote Top
Advertisement
Old 04-10-2019, 07:46 AM   #4 (permalink)
Photos: 25
Default
Thanks, Michael! That's a good start for me.
Old 04-10-2019, 08:02 AM   #5 (permalink)
mecompco's Avatar
Photos: 10
Default
Quote:
YW, There are some good YT vids on the topic, and possibly an article here. A challenge for me is getting the layout to look good. Some stamp shapes seem to work better than others. The stamps also tend to lift as you position them--even with gloves on the stamps like to stick to your fingers.
I did one Elegant Sierra using Portland Head Light (Maine) stamps for my Mom which came out pretty good, not sure if I have a pic or not. Please do post pix of your work when you try it.
Michael
PS: I don't know if you've sourced a mold yet, but I highly recommend Fred Wisson's tube-in molds: https://ptownsubbie.com
__________________
Michael
Fairfield, Maine
Old 04-10-2019, 08:11 AM   #6 (permalink)
Photos: 0
Default
The method I use is Elmers. The white will work but it doesn't dry clear so if it's a dark stamp it will have a haze. The "Clear Transparente" works the best for me. I use the same glue to glue on the stamps and seal them. Others use other products with no problems so I'm not saying my way is the best so you might need to try different things to find out what you like. I also like removing the glue from the stamps and I paint the backs to keep things from showing through.
Kenny Durrant is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
