Hobby Lobby and casting.
hanau
thomasville, nc, USA.
Have to go to Hobby Lobby Tomorrow and thought I might get the stuff to try casting.
What type of resin and I am looking for and what type of color would i need to get to go with the resin?
DozerMite
Banned
Our local HL only carries epoxy now. Try Micheals if they are close. Much less expensive to order online though.
Tim'sTurnings
Central Michigan
If you are going to Hobby Lobby or Michael's you can almost always find 40% off coupons to print out from searching the web. When my wife and I got to either, I always can find the coupons. Saves a lot of money.
joefyffe
Passed Away Aug 19, 2018
Indianapolis (almost Zionsville) Indiana
I think you will find a quart of Castin Craft, at Michaels, even with the 40% coupon will still cost you approx 20 bucks plus the catalyst comes separate. US Composites, on line, will sell you a gallon of Silmar 41 Poly Resin for less than 40 bucks plus shipping and the catalyst is included. (Ordered another gallon Yesterday!) Castin Craft pigment is liquid and has been known to dry up.. I like the Pearlex from HL better, or Mica from Coastal Scents, on line. Hope this sheds some light and saves some money! :)
Seer
Glendale,Arizona
Our HB carries Alumilte and about 8 different micas but I have a local source for Silmar I use about $40 a gallon with hardener
Drstrangefart
Woodstock, Ga. U.S.A.
Yup. At Hobby Lobby it cost us about $20 after the coupon. It DID come with way more catalyst than needed for the 5 pen blanks I got. It did its job and now I know I CAN cast and it's very enjoyable.
dogcatcher
TX, NM or on the road
Our Hobby Lobby carries both Alumilite and Castin Craft, the Alumilite is in the model car section, the Castin Craft is near the glues and candle making supplies.
elody21
Where do you order your Similar 41?
Alice
joefyffe
http://www.uscomposites.com/index.html for SILMAR 41
Alice
sbell111
Franklin, TN
Does silmar 41 have the same properties as the cast'n craft from Michaels? I mean is there anything different I would have to do to it?
There is no difference as far as how to make PR blanks. There may be some difference as to how chippy the resulting blanks are as you don't have any idea how long that tin of resin has been sitting around.
That being said, if someone wanted to buy some resin to see if he would like casting his own blanks, I would highly recommend buying from the local hobby store. Once you know that it is for you, you can start having the gallon containers shipped to you.
dexter0606
Cambridge, ON
Allan
Did you only get 5 blanks from one quart?? Must have been a smaller container.
There's 58 cu inches in a quart and a 1" x 1" x 6" blank is only 6 cu inches which would have gotten you almost 10
Just curious
BTW I like the Castin' Craft. Easy to get (in Canada) and it goes a long way when you're using Resin Savers
NewLondon88
Local Chapter Leader
Claremont NH
our 1st hobby lobby just openen up here in nh. you say they sell Alumilite ? what type? is there a type you try to avoid?
They have hobby kits, I saw the Clear in the Manchester store.. Look for a package with a photo of Mesquiteman's Cactus Pen on the cover. :biggrin:
DozerMite
Banned
No, they are different compositions. CC is much more brittle... nothing changes that. They gel and cure at different rates and require different amounts of catalyst. More colors affect CC negatively than Silmar.
CC works, but once one makes the Silmar leap, there is no going back.:wink:
Drstrangefart
Allan
Just curious
It was a 16 ounce can. I'm still learning and I used a rather large blank to form the mold around. Gives me room for error. I'd rather have one mildly oversize blank that forgives my mistakes than a normal sized one I have to cast again. I AM getting better blanks with less waste now.
hanau
