Help Needed
Curt Stivison
Logan, Ohio
I havn't been casting long and I need a little help. I used Alumilite ciear and pearl x powder (aztex gold). My pen blank came out cloudy and I am not sure why. Did I use too much powder? Any sugestions would be welcome.
Curt
Ed McDonnell
Melbourne, FL
Too much part A can result in white / cloudy resin. Did you measure out the two parts by weight (before adding pearlex)? If you measured by volume, you can have problems.
Ed
Curt Stivison
Logan, Ohio
Thanks for the reply Ed. I do measure by weight but the b is thicker and I end up using less b by volume. I may need to try a different scale.
