Help! Epic Alumilite fail - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 05-14-2018, 01:11 PM   #1 (permalink)
Photos: 0
Default Help! Epic Alumilite fail
My first attempt at casting ended up looking like an elementary school volcano experiment. I've read all of the posts I could find about foaming problems etc. I mixed the Alumilite clear by weight added some alumilite blue dye, stirred well and poured into my HDPE molds. Almost immediately it started to produce little tiny bubbles then just kinda overflowed the mold before I could get it into the pot. I stuck them into the pot anyway overnight and it came out looking a lot like it looked going in, just kinda' frozen in time like a lava flow. One blank had a piece of stabilized burl and the other was an empty blank. They both did the same thing. I did wash the molds before their first use but thought I did a pretty good job blowing them out with compressed air. I did use dados when making the dividers.
Is it possible that this was all caused because some water may have been hiding in the cracks of the dados?
ramaroodle is offline   Reply With Quote Top
Old 05-14-2018, 01:43 PM   #2 (permalink)
Photos: 34
Default
Certainly possible .
1080Wayne is offline   Reply With Quote Top
Old 05-14-2018, 02:13 PM   #3 (permalink)
Photos: 0
Default
What I have found out in casting.
Molds must be dry and heated to min of 70 deg.
Dieseldoc is online now   Reply With Quote Top
Advertisement
Old 05-14-2018, 02:16 PM   #4 (permalink)
Terredax's Avatar
Photos: 4
Default
It's most likely moisture. ANY moisture can cause the foaming.
Keep in mind, that polyurethane resins are very similar to polyurethane adhesives, with slight differences in formulation for the intended purpose, but mostly similar.
When using a polyurethane adhesive (think Gorilla glue), the adhesive is applied to one surface, and the opposing surface is dampened with water. This combination causes the adhesive to foam and expand, so the same reaction will happen when moisture is introduced to polyurethane resin. The foaming and expansion.
__________________
-John-
Terredax is offline   Reply With Quote Top
Old 05-14-2018, 02:47 PM   #5 (permalink)
Photos: 0
Default
Live and learn!
So, how high a temp can my HDPE mold take without melting if I stick it in the oven to dry it out?
Old 05-14-2018, 05:15 PM   #6 (permalink)
Brian G's Avatar
Photos: 4
Default
You'd be easily safe one degree more than the boiling temperature of water.
Brian G is offline   Reply With Quote Top
Old 05-14-2018, 05:32 PM   #7 (permalink)
Terredax's Avatar
Photos: 4
Default
Quote:
Originally Posted by ramaroodle View Post
Live and learn!
The melting temperature is 266 degrees.
__________________
-John-
Related Content
Reply
Bookmarks
Tags
alumilite clear , casting blanks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
