Has anyone made this blank?
Gary Beasley
Marietta, Ga. USA
It wouldn't be hard to do so long as you have a way to position the line. In tube casting would be the way to go so you can control the depth and appearance of the materials.
Curly
Saskatoon SK., Canada.
Charles if you have a green blank you like you could tube it and turn it down, CA the line to it and then build up a CA finish to cover it. You are pretty good at CA finishes as I recall. ;)
Lawrenceville, GA 30043
Thank you
Thank you for the kind replies and suggestions.
I may try on the blank cutoff to engrave a groove with my Dremel tool. Then fill it in with orange to simulate the fly line. My only reservations that this is on the surface and there is nothing to protect it from chipping out.
Will give it some more thought.
Thanks everyone,
Woodchipper
Cleveland, TN
Experiment as the CA might cause the thread to disappear. Rod building requires a color preserver in many cases to keep the thread from becoming translucent or transparent. Some builders use white thread- the thread disappears when the epoxy is applied.
