Hi Guys, Here is a pic of two similar dial gauges ( or manometers if you prefer)
The reason I'm showing them is to show the difference between Absolute pressure and Gauge pressure.
Both of these gauges have a full scale of 14 Bar ( 200psi ) but look closer at the smaller one. This one reads Absolute pressure and is calibrated to show normal atmospheric pressure as Zero. (Technically this is untrue - but don't worry about it.) The big one reads Gauge pressure.
The point is, if you use the small one, you can use it for vacuuming and pressurising without fear of damaging it. Both of these are made by USG ( US Gauge ) and are really quite cheap.
If you find a good stockist of these, they will even make up one with a dial that reads from -1bar to 0bar to +6bar, which is perfect for our needs. Although this one is fine and will be fitted to my new pot in the morning
