Evaluating a resin blank
budnder
Chicago/Tucson
I've been doing quite a bit of experimenting with resin casting (Alumilite and PR) and am looking for a process to evaluate the result... in other words, how do I know if a blank will make a "keeper" pen. What I don't want to do is waste time or a kit on something mediocre. I'm curious how others manage this.
The process I'm using at the moment is to standardize around a tube size (I picked 3/8") and keep a stock of different kits in that size. I drill the blank through at 3/8 and turn it between centers a bit before I cut or glue a tube in... if the blank looks good after I'm into it a bit, I'll pick a kit and glue a tube in and finish it into a pen... otherwise I'll discard it.
Anyone have a process they like for evaluating experiments?
SteveG
Eugene, Oregon 97404
If I have any doubts, I simply mark centers, and turn to a cylinder, then sand and polish as much as is needed to make a decision. There is no lost "meat" from the blank at that point, but if I am still undecided(rare at that point), I will turn it a little further. In general, just cleaning up a round blank, or taking off the corners by way of ruff turning is all that is needed.
budnder
Chicago/Tucson
Thanks for the suggestion - sounds like a good idea - I'll give that a whirl.
As most of the blanks I've been doing lately are round, I guess another variation to turning between two centers would be to just center drill one end and collet the other.
I like the idea of not having to drill the unknown blank, though - less work and leaves all options open.
