Differences in Alumilite forumlations
Good post, I have been casting a very short time using Allumilite clear by wt. with psi. can't get the smell out. Cut and finished then let sit in my office for A month still smells
This thread is from 2011. If you need to contact Curtis he no longer stops here and you need to get him on his web site. Just a heads up.
Wisconsin
I use Amazing Clear Cast almost exclusively. I have used it in single pours up to a box blank that's app. 4" × 7" which is far above the recommended usage with no issues. I also use it to make hybrids with zero issues. I do use it under pressure and really like that so far after 100s of different blanks I've had zero moisture issues unlike regular alumilite. Unless you are production pouring I see no reason not to use it over the other resins.
