Differences in Alumilite forumlations - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 11-09-2011, 11:25 PM   #11 (permalink)
Banned
Photos: 0
Default
Curtis, this is a great post!! But...can you decode the terms...shrinkage, shore, Elongation and so on. With a post of this detail, all the stuff that it means would be cool. Thank you sir!!!
Jim Burr is offline   Reply With Quote Top
Old 11-09-2011, 11:36 PM   #12 (permalink)
Head Moderator
MesquiteMan's Avatar
Photos: 18
Default
Quote:
Jim,
I did! See the first part of the post under definitions!
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Reply With Quote Top
Old 11-09-2011, 11:38 PM   #13 (permalink)
hewunch's Avatar
Photos: 3
Default
Ok, do you have the formula for transparent aluminum?
__________________
"Grow, grow where you are, anchor your roots underneath. Doubt your doubts, and believe your beliefs"
hewunch is offline   Reply With Quote Top
Advertisement
Old 11-10-2011, 01:01 AM   #14 (permalink)
Bellsy's Avatar
Photos: 0
Default
Quote:
Originally Posted by MesquiteMan View Post
Quote:
Originally Posted by Bellsy View Post
Great post Curtis. I was wondering if you have the same information about the West System 105 Epoxy and hardeners?
Dave
Well, since West Systems epoxy is not a casting resin, I did not include it. However, I do have the info handy so here it is!
West System 105 with 205 Fast Hardner:
Pot Life: 9-12 minutes
Viscosity: 975 CPS
Cure to solid (thin film, thicker applications will cure faster): 6-8 hours
Shore D: 83
Shrinkage: NA
Elongation: 3.4%
Temperature Resistance: 118 F
West System 105 with 206 Slow Hardner:
Pot Life: 20-25 minutes
Viscosity: 725 CPS
Cure to solid (thin film, thicker applications will cure faster): 10-15 hours
Shore D: 82
Shrinkage: NA
Elongation: 4.5%
Temperature Resistance: 123 F
What else ya got? :)
Hope that helps some!
The 207 hardener that makes it clear. Sorry I should asked for all 3 the first time around.
BTW.....what a difference in viscosity. That could be a BIG factor for some casts....Hmmm.
Dave
__________________
Dave in Ontario, Canada
Bellsy is offline   Reply With Quote Top
Old 11-10-2011, 02:19 AM   #15 (permalink)
Linarestribe's Avatar
Photos: 0
Default
Great info.
You posted that for the clear resins that vacuum or pressure is needed to remove bubbles.
I keep hearing vacuum for stabilizing and pressure for casting. My pressure pot goes to 50 and I have your chamber. Which is better for removing bubbles?
Jorge
Linarestribe is offline   Reply With Quote Top
Old 11-10-2011, 02:23 AM   #16 (permalink)
Head Moderator
Photos: 18
Default
Pressure without a doubt. I stated vacuum because that it what Alumilite says. I have found no use for vacuum when casting with Alumilite!
Quote:
Originally Posted by Linarestribe View Post
Great info.
Jorge
__________________
Curtis O. Seebeck
www.TurnTex.com
Old 11-10-2011, 03:10 AM   #17 (permalink)
arioux's Avatar
Photos: 0
Default
Great info Curtis thanks you. May i suggest that this text be put in the WIKI section under "Allumilite" . i think this information shoud be kept as a reference.
Just my .02
__________________
Alfred
Terrebonne
Qc, Canada
arioux is offline   Reply With Quote Top
Old 11-10-2011, 06:12 AM   #18 (permalink)
Photos: 25
Default
Quote:
Originally Posted by witz1976 View Post
Just curious for reference, Curtis but do you know the Elongation % of PR?
To me the 1% difference between clear and water clear means a tiny amount, however when I do not know the % of the comparison it is hard to make an educated analysis.
I included data on PR at the bottom of the list. Silmar 41 has an elongation of 1.5%
Wow big difference. Thanks for the info!.
__________________
-Dan Horowitz
witz1976 is offline   Reply With Quote Top
Old 11-10-2011, 04:21 PM   #19 (permalink)
Bellsy's Avatar
Photos: 0
Default
Never mind on the added info Curtis.....I managed to find it on the West System website after a bit of clicking and searching.
West System Properties
Dave
__________________
Old 11-10-2011, 04:56 PM   #20 (permalink)
Head Moderator
Photos: 18
Default
Dave
One thing to point out, Dave, at least for others, is that West Systems is a laminating epoxy, not a casting epoxy. Sure, it may work for casting but is not designed for it.
__________________
Curtis O. Seebeck
www.TurnTex.com
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
