Casting a stamp pen
Sahuarita, AZ
Now that I have pretty much everything I need to start casting, I want to try casting a stamp pen. I'm wondering if anyone knows what the best type of adhesive I should use to adhere the stamps to the blank.
Thanks!
arkie
Siloam Springs, AR
Stamp adhesive
If the stamps are new and PSA (pressure sensitive adhesive, or peel and stick), I find their own adhesive sufficient. However, you need to seal with CA before casting, and put an extra small drop of CA at any seams on the ends of the blank. If not, the PR will attack the adhesive, cause the tamps to lift off the tube, and the blank will be ruined. DANHIKT!
If the stamps no longer have adhesive, or if they are the older mucilage type (lick and stick), I use Elmers extra strength craft glue stick. This works well for me, and gives a short time to reposition the stamps before it locks them in place. Finger pressure for maybe 30 seconds is sufficient. You should seal these also with CA before casting.
I avoid Mod Podge like the plague. I have had too many blanks turn milky after casting, no matter how well or how long I thought I had dried them.
Jim
EBorraga
Passed Away July 17, 2022
Louisville, KY
I'm with Arkie. I use Elmer's glue stick. And make sure you seal it good with CA! I let it sit for 2 days after I CA. After 2 days I cast. I've had issues with CA fumes clouding the resin if I cast immediately
