Casting snake skin - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 09-13-2016, 08:07 AM   #1 (permalink)
Photos: 0
Default Casting snake skin
I am having trouble with casting snake skins. I'm using Alumilite and the casting is clear and turns out good, but for some reason spots on the snake skin are white or foggy looking. I am using CA medium and I was putting the blanks in the casting shortly after. But, later studying I found the CA glue has to completely cure and I with the reaction from the Alumilite this was causing this may be causing the milky color to cover the snake skin. So, after trying this and letting it dry for 24hrs I had better results but still some white places. The snake skin I use was just skinned and pin to a board and the snake was cleaned and left to dry naturally. It feels like paper pretty much when it's finished. Any advice on what may be causing this problem?
Thanks in advance for any responses!!
Crafturner is offline   Reply With Quote Top
Old 09-13-2016, 08:33 AM   #2 (permalink)
Photos: 161
Default
Are you removing the scales?
24 hrs may not be enough time for curing the CA, you might want to wait for several days before casting.
Cwalker935 is offline   Reply With Quote Top
Old 09-13-2016, 09:41 AM   #3 (permalink)
jttheclockman's Avatar
Photos: 84
Default
Check the library here. There are a couple tutorials there. I believe too from past threads on this and again you can use the search feature here quickly to find these, but the consensus was that alumilite was not the best resin for those blanks. I maybe wrong but easy to check out. Good luck.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Advertisement
Related Content
Reply
Bookmarks
Tags
alumilite , casting , problems , skin , snake
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
