Casting fishing flies into a pen blank
PSU1980
Mechanicsburg, Pennsylvania
I am going to attempt to cast small fishing flies into a blank. I plan on wrapping the tube with carbon fiber and then CAing the flies to the Carbon Fiber and then casting with Water Clear Alumilite.
After all of that, my question is: What pen kit has the thickest wall and will give me the best chance to not expose the flies when I turn to the bushings?
I would prefer a single barrel pen.
Any help would be greatly appreciated.
Tim
OLLIEwinz
nottigham england
you could probably try using some sort of majestic rhodium fountain pen.i would use nymph flies because they are smaller than most but you will have to be careful about the resin changing the shape of the flies.
-oliver
Jasper Indiana
I have found that the Sierra Vista has the thickest wall of any of the single barrel pen kits. The regular Sierra has wall thickness of .032" while the Sierra Vista has a wall thickness of .0565". There are probably more but these are the kits I normally use.
Mike
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Another idea to consider is wrapping the tube with rod making tread as opposed to carbon fiber. Plenty of colors available and a lot thinner. May open up the kit possibilities.
rd_ab_penman
Red Deer, Alberta, Canada.
I found that the Sierra series work best with the thick walls.
Les
