Anyone using PR with the Cast Right vertical casting System, or is it best with Epoxy?
Fordwakeman Member Joined Mar 21, 2013 Messages 224 Location Washington Jan 23, 2017 #1 Anyone using PR with the Cast Right vertical casting System, or is it best with Epoxy?
JohnU Member Joined Jan 31, 2008 Messages 4,951 Location Ottawa, Illinois Jan 23, 2017 #2 I cast with my own vertical system but use Silmar 41 polyresin all the time. Works well with Alumilite also.
jttheclockman Member Joined Feb 22, 2005 Messages 19,132 Location NJ, USA. Jan 23, 2017 #4 I do the same as John. This has been talked about recently so if you do a quick search you may find that thread.
