Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casting & Stabilization
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Reply
Old 11-11-2011, 05:12 PM   #11 (permalink)
Photos: 5
Default
Quote:
Originally Posted by seamus7227 View Post
not to change the direction of this thread, but what do the trees look like that they come from? Or the wood itself? I agree with Roger as well, throw them in a mold and get to casting! Its only 10:12pm here, what time is it there?
g'day all .The timber of the banksia makes a far more interesting pen than the pods they are ok for some turning jobs the timber is chocolate colored with various dark dolored flecks a rather dusty residue is the result of turning a recommend always use a mask as for a finish i use a product called stylwood that i have added a small quantity pure canauba flakes to
the finish is a rich and attractive pen .the down side there is a fair amount of waste due to imperfections in the timber but the result is worth the effort
penmantoo is offline   Reply With Quote Top
Old 11-11-2011, 05:22 PM   #12 (permalink)
Photos: 5
Smile
Quote:
Originally Posted by Justin_F View Post
Hi guys,
Can you please put on your thinking caps and give me some advice? I have been sawing Banksia Pods for some pens I've been asked to make and it seems a shame to throw out the bits left over. I have broken seed shells (half round bit bigger than your thumb nail), slices of varying thicknesses and the brown dust and red dust. (See pics).
What would you do with them and a bit of Polyester Resin??
All thoughts appreciated from you guys and gals!
Jus
Living in oz as i do why dont you try making pens from the timber of the banksia they really do make an interesting pen but there is some waste and a mask is a must
Old 01-16-2012, 06:53 PM   #13 (permalink)
Donovan's Corner's Avatar
Photos: 2
Default
I recently pretreated a Banksia pod with thin CA. I have turned the ends and cut the main body to pen blanks. I have seen no red fuzz and the outer skin is intact with very little tear out. The bits left over are in purple and blue PR. At 3/4 inches thick how long might it take to set up? This is my first attempt at mutt blanks...
__________________
Donovan's Corner is offline   Reply With Quote Top
Old 01-16-2012, 06:59 PM   #14 (permalink)
PenMan1's Avatar
Photos: 57
Default
I think I would start by placing the nut scraps on a piece of waxed paper, then carefully fill each void with a different colored stone and glue. Once dried, I'd run it over the belt sander to flatten everything, THEN, I'd cast them in clear resin and use them as interesting and unusual segments in pens.
IN FACT, if you have LOTS of scraps, I WOULD LIKE to try this!!!!
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor
Common sense isn't always such a common thing.
If it ain't broke.......then a little duct tape won't hurt it!
PenMan1 is offline   Reply With Quote Top
Old 01-18-2012, 10:53 AM   #15 (permalink)
Photos: 1
Default
Quote:
No one can answer this question for you as there are two many variables, such as temperature, moisture, amount of catalyst, etc. Generally, when I cast in resin, I'll just leave it under pressure overnight (or all day). It's probably overkill, but leaving it longer will do no harm.
__________________
Steve
Franklin, TN
Though we travel the world over to find the beautiful, we must carry it with us or we find it not. -Emerson
sbell111 is offline   Reply With Quote Top
Reply
Bookmarks
Tags
banksia , casting , offcuts
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
