alumilite
Fay Prozora
Port Angeles, Wa
I like it too buy it is too hard to get it out of the PVC pipe and I have mold making stuff coming so I will be making my own molds to cast pen blanks and bottle stoppers. It seems to work great with the silicone molds and I have a little cup that is silicone and it came right out of that cup so next payday I will try the PR resin in the pvc pipes to see how that will go... Good luck with your blanks... Fay
TBCbushings
Hampton, Va.
Ok I poured two blanks and they turned out really nice. The third one I poured today turned out like skim milk! I know moisture is a problem with Alumilite but I had no water around....UGH! How did it happen? Very frustrated.....Just a note. I did only mixed up 1 ounce of alumilite. Is there a minimum amount? The first time I mixed 3 oz and worked out great....
Brian
Abby
Lilburn, GA
I haven't used alumilite yet (but that's coming). But with the clear casting resin I use, I mix mineral spirits and petroleum jelly (about 50/50) and paint the sides of the mold. The mineral spirits evaporates, leaving a slight film of petroleum jelly on the mold. Works well with casting resin but cannot say for alumilite.
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
Brian
If you are going to use such a small amount, I recommend warming your molds before pouring. One oz is borderline not enough. For one, if you are off just a little on the ratio, it makes a big difference on a small pour. Also, a small pour does not generate enough heat of its own, thus the recommendation of heating the mold.
TBCbushings
Hampton, Va.
Ok third attempt with alumilite I warmed the mold up and this is the result. I was about ready to give up on alumilite but now I think I have it down. I really like the way alumilite cures.
daaveyboy
North East UK
Hi all
Can anybody tell me where I can buy alumilite in the UK.
I have just tried with Clear Polyester Casting Resin with a pressure pot and it was still runny after 24 hours ( I don't think I had enough catalyst in it)
Many thanks
seamus7227
Wichita Falls, TX
I want to know though, once you turn it, do you see any snowflakes on the tube? Also, which alumilite did you use. I tried the water clear and had mixed results
Lewiscostley
michigan
i'm getting snow flakes on mine. What's causing it? I've tried sealing the blanks and casting with out sealing. Some turn out fine, while others have the flakes.
Marko50
Orem, UT
With Alumilite, you must use a sealer that is polyurethane based due to the fact that the Alumilite is polyurethane based.
...just my .02¢
