Adhesive for small labels
Rogersab1223
Alexandria, VA
Hello everyone -
What do you typically use as an adhesive for smaller labels glued to tubes. For stamps, seals, cigar labels, beer bottle neck labels, etc. What do you use to seal them prior to casting?
Thanks,
Andy
Turned Around
Houston, TX
Hello everyone -
Thanks,
Andy
for my cigar bands, i use a thick CA. works for me every time and leaves nothing behind after casting.
Rogersab1223
Alexandria, VA
Hello everyone -
Thanks,
Andy
Thanks, I'm assuming you "brush" it on to get even coverage? Do you apply a sealant?
Andy
Turned Around
Houston, TX
no, i actually just use my fingers. go quick and steady so it doesn't stick to you and pull off the ink from anything you're gluing down. i don't bother with a sealant, just let the CA sit overnight or so before casting. if you do it right fter it's cured, the fumes from the glue will cause cloudiness under the resin
navycop
Virginia Beach, VA 23454
Do you have anything over your finger ie plastic bag, paper towel?
