$ 3.00 Experiment
jack barnes
Springfield, Ma.
Found this at Ocean State Job Lot, yesterday for $3.00.
needed a mold, used this from this just plugged the hole with 5 min opoxy.
resin is not clear it is amber. mixed blue and gold pearl ex. pressure pot about 15 hrs.
toaster over at 125 degrees for 1 hr. and ended up with this. sanded 320 to 600 and
MM to 12000
What do you think is this worth $3.00 or not? 1 gal. cans are $10.00
Jack
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Looks good to me. Very likely a similar formula to many of the PR compounds out there. May or may not work for clear casts, but for colored a definite yes. Nice find.
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
MM to 12000
Nope!
Much, much more than $3.00!:good::good:
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
It is polyester resin, just not clear polyester designed specifically for clear casting. Will work just fine for colored work as will any other polyester based fiberglassing resin.
ldb2000
Laurence Harbor, NJ, USA.
I have used "General Purpose" fiberglass resin with good results , As Curtis said it works well for color casting . Clear and lighter colored castings could be a problem but darker colors are perfectly alright .
Lenny
Searsport, Maine
It's hit or miss with Ocean State Job Lots around here. At one time I was buying 5 min. epoxy in the syringe style tubes for $1.50. They didn't last long (I got a lot of them) and I haven't seen any n there since. If you see it, buy it quick, as it may never be available there again.
jack barnes
Springfield, Ma.
What would the shelf life be on this? I bought 2 gals cans and they have 12 left. At $10.00 a gal. would it be worth while to buy more and keep stored?
soligen
Sterling Heights, Michigan
Thanks for posting this Jack, made remember I had some left over fiberglass resin, so I just cast it up as it was 1.5 years old. IT was a bit thick, but seemed to cast OK - havent turned it yet
ldb2000
Resin generaly has a shelf life of 1 year if stored in a cool location , if you keep it cold you can keep it for a couple of years . If it is stored in normal temps though the shelf life is reduced .
