Pen Box For 3 Bolt Actions
See more from adirondak5
adirondak5
Long Island NY
I am making 3 bolt action pens for an acquaintance , a Magnum , Standard , and Mini , they also requested a box to display / store them in and pretty much just asked for something fitting for the theme of the pens . I worked on a design for a little while today with my CAD program and here's what I came up with so far . A walnut box slotted for the 3 pens with a recess top and bottom to be lined with velvet or similar . 7 3/8" x 4" x 1 3/8" . I am thinking of neodymium magnet for a latch/closing method and small brass hinges on back side .
Here's a picture of the rendering so far , any tips or ideas are appreciated . I'll probably start on this tomorrow , don't know if I'll get it on the CNC but will get it prepped .
Inside top and bottom
Outside top
adirondak5
Long Island NY
Got the bottom of the box done with CNC'ing and rough sanded , will start setting up for the top section shortly . I made a few small changes , just to fit recessed magnets to keep lid closed . I think the inside recess will flock , it will be cleaner and easier than gluing in velvet , still pondering that . Here's a few pics
adirondak5
Long Island NY
I got more done on this than I thought I would today . Machined the inside of the top piece , flipped it and machined the eagle on top of lid . Came out good , just need to clean it up a bit more and get hardware , hinges figured .
Roughing tool path done
Finish tool path done
inside of top and bottom
Top cleaned up a little , wiped with naptha
adirondak5
Long Island NY
Thanks Luke & John :)
Its coming along , I sealed the inside of the box with SealCoat Shellac so the flocking base won't be sucked up by the walnut . I won't get to flocking until the weekend . In the mean time I cleaned up the eagle a bit more , sand top and bottom pieces and got a coat of MinWax Tung Oil rubbed on . That really made the eagle carve pop out .
adirondak5
Long Island NY
Got a little time to get the flocking done on the box today , now it'll sit for a few days and then I'll install the hardware and it will be done .
adirondak5
Long Island NY
Finished the box up , and also finished the pens that go with it last night , a magnum , standard , and mini all in gun metal with cherry burl barrels . They fit in the box good . The magnets I used were neodymium 1/4" disc x 1/16" thick , I was a bit concerned they were going to be too strong but they work fine , the box stays securely closed and does not require much force to open at all . I did recess the magnets so they don't come in contact with each other , iirc there is approx a 1/32" gap between them when lid is closed . Overall this was a fun project .
adirondak5
Long Island NY
GREAT presentation of a few very nice pens!!
VERY WELL DONE!!!
Thanks very much Ed , very kind of you .
Fantastic box.
I'm amazed at the depth of detail you get with CNC.
Congratulations
John
Thank you John I do appreciate that .
I used a .125 tapered ball nose at 7% step over , it took about an hour to carve the eagle , I could have used a smaller 1/32 tapered ball nose at about the same step over and gotten even better detail but the carve time would have been well over 3 hours . The interior and outline profile of both halfs of the box took about 10 minutes to machine out . You have to kind of balance what is acceptable with what is possible when it comes to relief carves with the CNC . As it was , there was very little clean up needed on the top carve so it was a good balance .
Chris Labedz
Channahon IL.
