Round #2 - Ball Point Pen contest
Please choose your top 3 pens
  • Pen 1
    Votes: 11 7.9%
  • Pen 5
    Votes: 32 23.0%
  • Pen 6
    Votes: 18 12.9%
  • Pen 7
    Votes: 59 42.4%
  • Pen 9
    Votes: 37 26.6%
  • Pen 10
    Votes: 31 22.3%
  • Pen 18
    Votes: 24 17.3%
  • Pen 19
    Votes: 17 12.2%
  • Pen 23
    Votes: 26 18.7%
  • Pen 24
    Votes: 70 50.4%
  • Pen 27
    Votes: 14 10.1%
  • Pen 28
    Votes: 18 12.9%
  • Total voters
    139
  • Poll closed .
bobleibo
Utah
Welcome to Round #2 of the Ball Point Pen Contest​
Our original plan to have the top 10 entries from round #1 move to round #2 has been
expanded to 12 due to a 3-way tie for the 10th position.
The order listed below has no relevance to the # of votes each pen received.
Pen #'s are listed in the same order as round #1.​
Please vote for your TOP 3 choices to determine the winners of the 2016 Ball Point Pen contest.
This poll will close on 2-26-16​
bobleibo
Utah
Pen 1
Kit used: Gearshift Pen
made with USPS classic chopper stamp on aluminum foil with alcohol ink colored foil trim cast in PR.
bobleibo
Utah
Pen 5
Kit used: Chrome CSUSA Artisan Clicker
I chose the clicker kit due to the long body and design opportunity. The blank started as an El Mostro alumilite blank. I cut 13 even pieces from it and used 12 pieces of aluminum to segment (Happy 12th IAP!) it is a simple design yet challenging due to the exactness of the tube and the clicker kit gives no room for error.
bobleibo
Utah
Pen 6
Kit used: European style twist pen kit
As far as the blank, there was really nothing too special. Its was a nice piece of clear hard maple. The challenge was to get the cross to start and stop in the right place once the pen was turned. I added a red band in the middle of the pen to complement the red cross... and that I don't really like the bands that come with the pen kit.
bobleibo
Utah
Pen 7
Kit used: WallStreet 2 in Black Titanium
Pen has a Maple Burl center, surrounded by curly Walnut. Pedals/Scallops are made from white Corian and a Navy/Purple with white spec Corian round out the top and bottom. Aluminum sheeting is used to separate each of the materials. Finish is with CA Glue polished to 12k grit.
bobleibo
Utah
Pen 9
Kit used: Southwest Twist Pen Kit – PennStateInd
SWPEN Twist pen with separate segments using mesquite, walnut, yellow heart and koa. Accented with plastic accents and use of turquoise True stone to complement the pen clip and center ring of the SWPWNKIT.
bobleibo
Utah
Pen 10
Kit used: SPW Royale in Gun Metal
This pen is made up of 227 pieces and lots of CA. I first split a blank both ways and sandwiched a piece of plastic sandwiched between two pieces of wenge veneer. I then turned it round and drilled for the tube. I cut slices off the rounded blank and glued them on the tube, slightly twisting and alternating between slices of the blank and red plastic cutting sheet material.
bobleibo
Utah
Pen 18
Kit used: PSI Vertex Click Pen Kit
I like the simple lines and smooth operation of the Vertex Click. I also like the use of bird feathers to make a blank. The intricate patterns in the feathers are very attractive. I bought a Mixed Feather blank made by JohnU (member) which had been designed and made for a different pen kit. I added a piece of wood (Lignum Vitae) to each end of the blank so that it would fit the Vertex. No modifications were made to any part of the Vertex pen kit and all parts were used.
bobleibo
Utah
Pen 19
Kit used: Cigar in Chrome finish
The wood is Padauk with black and white plastic accented with aluminum flashing. The wide stripe is some 1/4" leather I had laying around. I used CA for my finish. If you like orange dust everywhere Padauk is the wood for you.
bobleibo
Utah
Pen 23
Kit used: Cigar Pen
This spalted Magnolia blank was cross cut from a large block. I stabilized it before turning it for this cigar pen. The finish is a CA/ BLO finish followed by Novus 3 & 2 and buffing.
bobleibo
Utah
Pen 24
Kit used: Satin Copper Cigar
This eight-loop Celtic knot started with an oversized (nearly 1") cherry blank milled to an octagon. The segments in the loop were constructed of colored veneer; a gray strip was sandwiched between two white strips, which then was sandwiched between two burgundy strips. The eight-loop knot was constructed just like a four loop knot, except there are eight kerf cuts referenced off of the octagon faces in a 1, 5, 3, 7, 2, 6, 4, 8 order. The pin stripes were made from the same veneer as the knot material. The kerfs were ripped the length of the lower barrel blank to a depth just short of the diameter of the brass tube. The finish was CA, and the plating is satin copper.
bobleibo
Utah
Pen 27
Kit used: Liberty
This pen uses Ebony wood as a base. I turned the wood down a bit past the bushings, sanded it and cleaned it. Then made a design in pencil on it. I painted it with acrylic paints and finally finished it with applying colored pencil to give it some depth. The wood shows through around the design so you get to appreciate both the wood and design. Finally sealed it and put a CA finish on it to protect the design and used micro mesh and water to smooth it out and finally I buffed it to a shine.
bobleibo
Utah
Pen 28
Kit used: SPW LE ROI ROYALE IN RHODIUM
"All inlace with a little copper." Love to turn inlace acrylester, which I know some people hate. Wanted to do something with all the cut-offs so I glued up a bunch of segments separated by 0.025" copper sheeting, drilled out for the tube, then turned. Actually turned nicer than a straight piece of inlace, probably because I took my time with the copper segmenting. Thanks for looking!
