Pen Box Voting - Round 2
You may vote for 1 of the 5 boxes
  • Box 1
    Votes: 8 7.5%
  • Box 2
    Votes: 11 10.3%
  • Box 4
    Votes: 10 9.3%
  • Box 7
    Votes: 69 64.5%
  • Box 11
    Votes: 9 8.4%
  • Total voters
    107
Monty
Group Buy Coordinator
Pearland, Texas, USA.
Here are the top 5 vote getters from round one.
Round 2 is now open for the next 72 hours.
Box #1
The box is made from walnut veneer with a Gator back paper. The sides(box)made from 2" solid wood wheel and adhered to the veneer with double sided tape. The catch (lid closure) is elastic ribbon that secures to the wood button for easy closure. The total weight of the box is under 20 gram. Holds up very well despite the delicate nature of veneer.
Box #2
Tell us about your entry: Xtreme snap fit pen box. All crosscut segmented construction.Made from Zebrano and Panga Panga.They are both very porus woods,I like the effect so I tried to highlight it.The bottom has a blue/black resin center with an inlaid segmented rimgStarted with a 8 stave blank then cut and sptral stacked the disks.the center was made from some of the leftover blank sandwiched between the 2 woods.the inlay rings were also cut from the base blank.The finish is thin flex CA.
Box #4
Made from a block of cedar. Using a torch to get a burned/aged look to simulate a buried treasure chest to house one pen with a similar theme. Cedar was shaped and cut on band saw and then I used a forstner (2") bit to hog out the body of the chest. The box was mated with black stamped out hinges that were purchased along with clavos (nails)to give the appearance of an old/weathered treasure chest.
Box #7
The box is made from Hawaiian Curly Koa and Gabon Ebony. The exterior features a hand rubbed lacquer finish which surrounds an interior carefully upholstered in plush imported satin. The design is elegant...intended to compliment the "best of the best" high end pens...so the cushy soft interior will accept the largest of the component-set pens, but will also provide a suitable home for "Jr." series pens. Consideration was given to ease of use: the interior space and shape invitingly allow the pen owner to easily grip his or her pen when removing it from the box. A pleasing design note: a set of nearly unseen hinge stops were utilized to restrain the lid at an attractive angle when open, rather than allowing the lid to "plop" fully down to the desk surface.
Box #11
This Pen Case is made from a 10 " piece of a Black Locust branch. Pruned by Arborists and left on the ground, the bark had fallen off exposing the Bast of the branch which is the first layer beneath the Bark. Groves were cut on the table saw to hold the pen. The lid to the box and base were lightly sanded to blend in the sides that had been glued in place. I left the top of the box Natural showing the cracks from years of being exposed to the weather. The inside was solid. Picture hanging pins were used to create a pivot point through the sides of the top into the base to allow the lid to open and store your favorite pen. The first photo is taken vertically to the show detail of the finished lid. A light coat of oil was applied to the box as a finish. Overall Dimension 2" x 2 "x 7" .
Monty
Just 83 votes cast so far and a little over 24 hours left to cast your vote on these one-of-a-kind beautiful boxes. We had about double this number of votes in the primary. Lets see if we can beat that.
