Turncrafter Pro belt
glycerine
Fayetteville, NC
I'm not seeing much info on replacement belts for the Turncrafter Pro. I bought one of these lathes used and while the belt that's installed looks good, I don't want to be without one just in case. Is this a universal belt? Any info would be appreciated. Thanks...
surveyzo
Sinton, Texas
You should have recieved an extra w/ your order. But if you didn'nt, when you make your next order put the belt # in the comments box. You'll find the # in the owners manual. They don't show the parts online. They're 5 bucks.
glycerine
Fayetteville, NC
I bought it used from someone else and they misplaced the belt. I do believe that I have the owner's manual though, so I'll take a look in there. Thanks.
glycerine
Fayetteville, NC
Ztcl3-26 drive belt
Thanks. I also contacted Penn State Industries through their website and they gave me this info:
"THE DRIVE BELT IS AVAILABLE. THE PART # IS: ZTCL3-26. THE COST
IS: $5.00 EA.
THIS ITEM .MAY NOT BE ON LINE AT THIS TIME. YOU CAN CALL OUR CUST SERVICE
AT 1 800 377 7297 BETWEEN THE HOURS
OF 8AM TO 5PM EST MON -- FRI,
TO PLACE AN ORDER.
NOTE: A FEW MONTHS AGO, SOMEONE PASSED ON A GOOD TIP TO ME. IF YOU
INSTALL 2 BELTS PER BELT CHANGE (KEEPING THE X-TRA BELT SECURELY
FASTENED TO THE INSIDE OF THE HEADSTOCK HOUSING WITH A SMALL CABLE
TIE), ALL YOU HAVE TO DO ON THE NEXT BELT CHANGE IS CUT OUT THE BAD BELT
AND INSTALL THE NEW 1, AND CONTINUE WORKING."
rjwolfe3
Mansfield, Ohio, USA.
Not sure that's possible. The thing looks indestructable.
It might it you change pulleys often. But I never change them since I have the variable speed even though I am sure that is the wrong thing to do lol. I bet you could over tighten the motor and lead to premature failure as well.
KD5NRH
Stephenville TX
Depends on how well they deburred your bed casting: mine had about a 1/32 or so interference into the belt path on the highest speed setting. Just enough to shave the belt down pretty good. A couple seconds with a file is enough to fix it, but you have to know it's there first, then you have to take the headstock off to get to it.
lpierce65
Brazil, Indiana
My Turn crafter pro quit tonight..actually it would not turn on to start with thought it might have been the brushes checked them and cleaned up the armature with a eraser its still wont start.. looks like it might be in a switch in the speed control box or something else in there anybody have any ideas what to check for.. PSI just sells the Speed control with the Motor combo.. dont see the individual parts listed anywhere..
any help greatly appreciated
Larry Pierce
Akula
seabrook, texas, USA.
Just got off the phone with PSI. I need a belt and figured, get a couple. I have had to order them before and yes, they were $5.00.
Now they are $15 each. Lady told me they never sold them for $5.00
Like I said, I have ordered and replaced the belt a couple times and I paid $5.00...so it must have been with someone else, not PSI.
Any tips where to pick them up before I hit google?? LOL
n5zkz
Texas, USA
I know this is an old thread but this is still a valid question.
I have seen these belts posted anywhere from $25-$70 yes, that's right $70.
The belt size is a 250J3 available on Amazon.com for about six dollars as of 12-30 2018. I'll see if I can add a link to it. I hope this helps those of you who have these beloved old turncrafter lathes.
https://www.amazon.com/PowerDrive-2...TF8&qid=1546188253&sr=8-2&keywords=250j3+belt
monophoto
Saratoga Springs, NY
There was a related thread a few days ago that identified this source. Prices are much lower than the Amazon price, BUT shipping increases the effective cost quite a bit. The person who identified the source said he had purchased belts from this supplier and vouched for the quality.
I ordered a replacement belt from PSI shortly after I bought my Turncrafter about 5 years ago. At the time, they sold in sets of two for around $20. Both Amazon and VBelt Supply are much less, even with the high shipping.
No surprise - any time you purchase renewal parts from the original manufacturer/distributor, you have to expect to pay a premium price. Just look at what parts for you vehicle cost at the original dealer compared with NAPA! And that's not criticism - it costs money to stock miscellaneous parts, and that cost has to be carried forward as a premium price in return for the convenience of purchasing them at the dealer.
I had to replace the belt on my lathe after five years - in my case, the symptom was that the belt got pretty noisy.
