Turncrafter Pro
richstick1
Woodruff, Wisconsin
Jared - the TC Pro is a good lathe by all counts. It doesn't get the press that other mini lathes get such as the Jet 1014, but is virtually identical, except the TC Pro actually has a bit more bed length. PSI has produced some lemons and some winners. The TC Pro is one of the winners. BTW - glad to see another person from northern WI on here - I live up in Woodruff [:D]
WWAtty
I've had my TC Pro w/extension bed for about 2 years now. Great little lathe, and the price was right. In addition to lots of pens, I have turned a few small bowls and a couple baseball bats on it without any problems.
Only complaint is that the motor doesn't turn well when it is cold (i.e., below freezing). Perhaps the bearing lube in the motor is the culprit. I make sure to warm up my shop before running the lathe in cold weather - it runs fine then.
Cheers.
