When you purchase the Tormek, be sure to check out their packaged deals. The prices are better if one buys the machine with Tormek's packaged accessories vs. buying separate ones. The "newer" tool angle setting tool is really a vast improvement over the one that comes with the machine.
Their demo videdeo says the tools can be sharpened in 60 seconds ... you best expect a bit longer time until you become very accustomed to using the machine. Scary sharp takes on a new meaning when achieved with the Tormek.
I like the machine for one simple reason right up front ... that being the fact that there is far less tool steel removed from our expensive tools when compaired to the greater amount when using a 'regular' grinding wheel. Grinding is very different when one is attempting to sharpen their tools. The edge achieved when grinding is equal to the edge obtained from the Tormek, but more metal is quite often removed to achieve the same sharp edge.
If the user keeps the wheel 'dressed up' level with the diamond wheel dressing tool, then an edge of very keen sharpness is achieved with very little wear to the tool. [
