Tighter tolerance for drill bits
chartle
Pgh, PA
For 7mm tunes, what is the best fitting drill bit to reduce tolerance but not too small?
https://m.facebook.com/?_rdr#!/rvatyndall/
Are you having fit issues? I've always used a 7 mm drill bit and with glue (epoxy rarely use CA) the tube fits just fine.
If you have a lot of slop do you maybe have some sort of issue like a loose chuck or bent drill bit and its making bigger holes?
Charlie_W
Sterling, VA USA
My rule of thumb is to drill 0.010" larger than the tube.
A pair of digital calipers and a large box of drill bits is a must. A 115 piece set with fractional, letter and number bits works for me.
Also use a centering bit or skew to give a centered divot for the drill bit......drill on the lathe.
