I've been trying to find some to make bolt action pens. I've got some for comfort, slimline, and executive. Can't find the bolt action ones though. Anyone have any suggestions? Thanks, Jim
You don't need bushings to TBC.
Les
Thanks,
Jim
PSI has them here.
PSI has them here.
Those are not turn between centers bushings They are standard mandrel bushings
If the small end of the bushings I referenced fit inside the tube for a bolt-action and you use a 60° drive center and 60° live tail stock center, what's the problem. Not that I pretend to be an expert.
Been busy las two days...
