Taps for Kit Less Pens Caps - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 06-27-2017, 10:37 AM   #1 (permalink)
Photos: 66
Default Taps for Kit Less Pens Caps
Can anyone shed some light on the type of tap needed to create the threads for the cap when creating a kit less pen?
I am investigating a possible group by for taps and dies used for these types of pens and have price quotes for plug and bottom tap.
I am sure that many of us would like to get one or the other of these taps.
All help would be appreciated.
eharri446 is offline   Reply With Quote Top
Old 06-27-2017, 11:45 AM   #2 (permalink)
Photos: 1
Default
I use plug taps for kitless caps. I can see some positives for bottoming taps but they aren't necessary in my opinion. You could use the bottoming tap also to cut cap threads but they don't have a lead in and would likely make cutting the initial threads more difficult.(opinion only)
Mintman is offline   Reply With Quote Top
Old 06-27-2017, 11:47 AM   #3 (permalink)
Photos: 1
Default
You might want to check with the supplier. I believe in a previous group but the tooling costs and quantity discounts used the combined number of plug and bottom taps.
Advertisement
Old 06-27-2017, 12:09 PM   #4 (permalink)
Photos: 1
Default
The reason for a bottoming tap is to end the threads cleanly when you make a translucent or clear pen. To cut enough threads for full engagement with the barrel threads with a plug tap you will have the taps tapering threads fading off past the ones you need. So to eliminate that if you want you start the threads with a plug tap and stop before getting to the length needed for full engagement, swap to the bottoming tap and finish cutting. If you aren't bothered by the threads being longer than needed or only work with dark materials like ebonite then the plug tap is all you need. The bottoming tap is optional. Some materials can be cut with a bottoming tap only but with brittle material or metals you need the plug tap first.
It is similar in principle to cutting the barrel thread. When your die stops at the shoulder you turn it around and finish by cutting to the shoulder so the threads don't taper up to it. The die having the threads relieved on the side of the die with the writing on it to help start it.
It's all about personal aesthetics.
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 06-27-2017, 01:38 PM   #5 (permalink)
IAP Activities Manager
mredburn's Avatar
Photos: 83
Default
Elwin what sizes did you have in mind to have made?
__________________
Life occasionally offers us the opportunity to make very very hard choices. I have had such offers.
Level 6 Pen Wizard, smoke, mirror and sleight of hand enabled.
Mike.
http://www.silverpenparts.com
mredburn is offline   Reply With Quote Top
Old 06-27-2017, 01:43 PM   #6 (permalink)
Photos: 1
Default
That absolutely makes sense for a transparent blank! I haven't made a demonstrator yet but figure I should consider at least one bottom tap!
Old 06-27-2017, 03:01 PM   #7 (permalink)
Photos: 66
Default
Mike, there is a thread under Group Purchases/Group Purchase Research/ called Group Buy for Triple Start Threads that has all of the information. However, I have pricing information for M14 x .8, M13 X .8, M12 x .8, and M11 x .8. These are all triple start taps and associated dies.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
