Joebobber
I've had this thing a year and about 3 months ago it started wandering badly. It seems like it was going to the right at around 20 degrees. This started after the old blade caught the lower guide(?) which had wiggled loose. The blade snagged and then let loose causing the guide or something to jump up into the table from below. I noticed one of the lower guides was missing. I bought a new lower guide assembly and put it on. Got everything lined up best I could, and square, and adjusted the guides and blade. Still goes to the right and wanders on thicker wood. I've gone through geeze about 7 or 8 blades with this thing since Christmas last year. I use it multiple times a day, every day. I cut wood, corian, and some catlinite and once alabaster. Any ideas on what might be wrong? The guide assembly is held on by 1 bolt so it moves quite easy if it comes loose. I've never had a bandsaw before so I'm only adjusting everything based on the manual and You Tube videos.
