Shop Made Jaws for Bentwood Ring Turning
Talfalfa33
Dallas, Tx
Just finished a set of jaws to fit on my Supernova 2 chuck. I've been trying to figure out how to make a expanding mandrel to hold the rings steady, but just no dice. So I took some pieces of aluminum and started machining on the Bridgeport and this is what I came up with. The hardest part was turning from a 1 inch square down to 0.470 round without a metal lathe. But after burning one full carbide insert, got it done. So far it's working like I expected. I never remember to take pics through the process but I think you all get the idea.
It's been too cold here to spend any time in the garage so I've made a few bentwood rings. I've been using a dowel that is slightly undersized with some masking tape for a snug fit. I still don't have a good way to secure them for sanding/finishing the inside.
I use a rig like this too polish duck call bands, I also have some that are smaller that I use to make all wood rings. The expander is a pipe plug, it has a taper to it that expands the 4 splits in the wood. You can buy pipe lugs at Lowes and Home Depot, but my small ones came from hot rod parts supplier, I believe it was Summit Racing, they go down to about an 1/8". The taps can be also be bought there.
I was thinking of making something similar. I was going to use a lag bolt to expand it out, but the pipe lug looks better.
I live 2 miles from Summit Racing and drive past it almost every day. Guess I'll have to stop in after work.
Thanks.
Lowes also carry's the smaller sizes in black pipe and even smaller in brass, look in the Watts section!!! This may save a few cents.
That idea looks great, but how would you do a slanted inlay and then Tilt it the other way so that the two inlays cross?
