Shop made Carbide tipped turning tools - FORE! - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 01-21-2011, 10:55 AM   #1 (permalink)
randyrls's Avatar
Photos: 67
Thumbs up Shop made Carbide tipped turning tools - FORE!
These are two turning tools I made for myself and a friend in our turning club. They are 5/8" x 18" hexagonal stock. I turned the shaft portion of the
The tools are very handy on wood and will remove wood almost too fast!
On acrylics I found them "grabby" and prone to create chip-out. I have more stock and more grips. I think a round one is in the future.
AND; YES those are golf grips used as handles. FORE!
"I think that was a slice!"
(Insert your own Golf jokes here!)
__________________
Randy S.
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
Practice random kindness and commit senseless acts of beauty.
randyrls is offline   Reply With Quote Top
Old 01-21-2011, 11:05 AM   #2 (permalink)
Photos: 11
Default
Very cool. I like your design. For 5/8" stock, did you use a 15mm blade?
__________________
Brian
Apopka, FL
bking0217 is offline   Reply With Quote Top
Old 01-21-2011, 02:40 PM   #3 (permalink)
wood-of-1kind's Avatar
Photos: 306
Default
[quote=randyrls;1159360]On acrylics I found them "grabby" and prone to create chip-out. I have more stock and more grips. I think a round one is in the future.
[url="httpQUOTE]
As someone who makes and sells carbide tools (professionally), the ROUND carbide inserts will certainly be better matched with acrylic blanks. Less of an opportunity to 'catch' with a round as opposed to 'square' inserts. Very nice tool that you have created.
__________________
SKOGGER & ROTONDO - "original" choice for carbide pen tools.
http://www.wood-of-1-kind.webs.com/
wood-of-1kind is offline   Reply With Quote Top
Advertisement
Old 01-21-2011, 05:32 PM   #4 (permalink)
Photos: 75
Default
I suggest the R2 cutter on plastics. Works great for me - so well that I start sanding my homebrew PR blanks with 1000 grit. But, I never got the knack for roughing with the carbide cutter. I rough plastics with a skew using a planing cut, which helps prevent the chipping.
__________________
Dennis Cabell
Sterling Heights, MI
soligen is offline   Reply With Quote Top
Old 01-21-2011, 07:00 PM   #5 (permalink)
randyrls's Avatar
Photos: 67
Default
Quote:
No, I believe they are 14mm I made the shaft wide enough so it will not cut on the side. The 5/8" hex stock is measured from flat to flat, so the distance between hexagonal points is about .717"
__________________
Randy S.
Old 01-22-2011, 10:55 AM   #6 (permalink)
Photos: 0
Default
Where did you buy your inserts?
__________________
Warren Gibson
www.signaturepenworks.com
Denver, NC
warreng8170 is offline   Reply With Quote Top
Old 01-22-2011, 07:31 PM   #7 (permalink)
randyrls's Avatar
Photos: 67
Default
Quote:
I believe I got them from Peter (Wood-of-1kind) who posted above.
Thanks Peter!
I still have one of the small-ish round inserts and I may try that next on a round shaft.
Look on Ebay for seller joebill1
__________________
Randy S.
Old 09-26-2011, 09:38 AM   #8 (permalink)
Photos: 23
Default
I have been using a roughing gouge to turn the bulk off my PR and turn to my rounded skew for detail. But at a club meeting this past Saturday, I had the opportunity to use one of your carbide tools. I stood the blade up at around 60 degrees and sliced the PR off into fine ribbons. It didn't grab for me and I could see where the corner would grab. I may look into getting one with the R2 insert.
homemade is offline   Reply With Quote Top
Old 09-26-2011, 09:42 AM   #9 (permalink)
hewunch's Avatar
Photos: 3
Default
I love the hex bar of my carbide tool. I regularly put it on its side and run it like a skew.
__________________
"Grow, grow where you are, anchor your roots underneath. Doubt your doubts, and believe your beliefs"
hewunch is offline   Reply With Quote Top
Old 09-26-2011, 10:36 AM   #10 (permalink)
Brooks803's Avatar
Photos: 235
Default
Quote:
+1 I have the same tool as Hans and to be able to lay it at an angle like a skew with a SOLID base is absolutely a dream to use. I have the same cutter head on mine and use it one everything I turn. It takes a little getting used to for acrylics but I wouldn't change it for anything else.
__________________
"Give a lazy man something difficult to do and he will find the easiest way to get it done." - Me
Brooks803 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
carbide , carbide tip , carbide tools , tip
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
