sharping carbide bits - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 11-12-2017, 11:35 AM   #1 (permalink)
Photos: 0
Default sharping carbide bits
What is the best process to sharpen carbide wood turning bits?
Dieseldoc is online now   Reply With Quote Top
Old 11-12-2017, 11:44 AM   #2 (permalink)
Photos: 0
Default
I have seen that some people lay the bit face down on a diamond cutting card and simply move it back and forth. Donít know if it works
Gwatson50 is offline   Reply With Quote Top
Old 11-12-2017, 01:15 PM   #3 (permalink)
Photos: 0
Default
I have done this and it makes them better, but nothing like new.
PatrickR is online now   Reply With Quote Top
Advertisement
Old 11-12-2017, 01:33 PM   #4 (permalink)
JimB's Avatar
Photos: 11
Default
I've used the method mentioned but move the cutter in a figure 8. It improves the cutting edge but I agree it is not as good as new.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 11-12-2017, 01:39 PM   #5 (permalink)
Photos: 0
Default
Craft Supplies put out a short video a while back:
https://youtu.be/kUOuAPimjP4
cjester is offline   Reply With Quote Top
Old 11-12-2017, 01:54 PM   #6 (permalink)
mecompco's Avatar
Photos: 10
Default
I have a set of the small diamond cards. I use the fine, then the ultra-fine. Moisten with water, then face down, I go around in a big circle 50 times, then in the other direction 50 times. Then I go back and forth 50 times and back and forth the other way 50 times. Then I move to the ultra fine and repeat. Takes less than 10 minutes.
I agree the edge is not quite as good as new, but it certainly more than serviceable. I can usually get four or five blanks per edge on my R2 cutter before sharpening again. More if turning wood, less if turning finicky blanks like Acrylester. I've probably turned at least 100 pens on the cutter I'm using now.
__________________
Michael
Fairfield, Maine
mecompco is offline   Reply With Quote Top
Old 11-12-2017, 08:12 PM   #7 (permalink)
TattooedTurner's Avatar
Photos: 267
Default
I've used a diamond card lubricated with WD-40 - thanks to YouTuber Gord Rock for the idea. While nothing like new, it did breathe new life into them and I'm sure they'll last awhile before I need to buy new ones.
__________________
Jay
TattooedTurner is offline   Reply With Quote Top
Old 11-13-2017, 02:32 PM   #8 (permalink)
Photos: 0
Default
I’ve used the diamond card along with cutting fluid to sharpen my carbide tools with mixed results. What I’ve found works best is just buy new inserts. I know this can be pricey but I’ve found AZ Carbides has some pretty good prices and ship quickly.
The other thing I’ve noticed are the inserts I get from AZ Carbides seem to be a little sharper than others purchased. May or may not be true, it just seems like it to me.
That’s azcarbide.com
__________________
Dennis
Imaginethat is offline   Reply With Quote Top
Old 11-13-2017, 04:15 PM   #9 (permalink)
Photos: 0
Default
Quote:
Originally Posted by Imaginethat View Post
Iíve used the diamond card along with cutting fluid to sharpen my carbide tools with mixed results. What Iíve found works best is just buy new inserts. I know this can be pricey but Iíve found AZ Carbides has some pretty good prices and ship quickly.
The other thing Iíve noticed are the inserts I get from AZ Carbides seem to be a little sharper than others purchased. May or may not be true, it just seems like it to me.
Thatís azcarbide.com
Wow! Those are expensive. I get mine from Global Tooling and Supply at about half that of AZ Carbide.
larryc is offline   Reply With Quote Top
Old 11-13-2017, 10:01 PM   #10 (permalink)
Kelley Crafts's Avatar
Photos: 0
Default
I'll agree with above, you can sharpen with diamonds but getting new inserts is better. If you went with the EWT tools there are definitely a lot of sellers who have inserts that fit their tools for cheaper.
__________________
www.kelleycrafts.com - pen blanks - knife scales - turning tools
Kelley Crafts is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
