Rotary pen laser
Anglesachse
Rhauderfehn, Germany
Well finally got my homebrew rotary laser running.
2.5w laser
2x NEMA 17
Eleksmaker MANA SE
Laser GRBL software
Very happy with the results just need to make a better casing as this one resonates to the fan:mad:
bwg
Pittsburgh
I like your set up. I am trying my hand at something similar (a sort of eggbot only with a spindle.) It would be sort of like a cnc-pen wizard.
Is your stuff all laser or have you fooled around with any spindles?
Anglesachse
Hi Bruce,
I do have something in the pipeline in this direction.
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I really like that design Andrew. Is it your own design? I like the choice of using linear rails. You should sell them as kits or complete machines :biggrin:
I guess the little tailstock is spring loaded?
Having the Z axis at an angle is cool too. Compact but out of the way at the same time. :)
Really cool !! Looking forward to seeing the completed project.:wink:
I might even have to wangle a factory visit to Ratingen and steal it from you!!:biggrin:
bwg
Pittsburgh
That is very nice. I like the z axis mounted on y. Do u have an idea on how you will control it.
Anglesachse
Thanks Skip,
The only spring loading is my thumb when I press the tailstock in position and tighten the screws, but this should be more than enough.
Here`s a pic of the spindle, made from a brushless motor.
Let me know if you come over to Ratingen so that I can secure my shop
Anglesachse
Bruce,
At the moment I am not so sure which software to use other than it will run GRBL, and probablly as hardware Ramps 1.4.
The software and computer side I usually get from my son. Its the best when you have a tame CNC machinist:wink:
Anglesachse
And the first order is engraved and ready to send.
26 Polaris with Oak. Engraved with names and Company Logo.
I was surprised how easy it was using Laser GRBL. a couple of tests on dowel and then go. About 45 min for all including setting up.
I think my NEJE is going to retire
