Russknan
Today, I am finishing up a bench for my new-to-me (used) Nova DVR XP lathe. Though not a fine piece of furniture, it is built like a brick . . . bench . . . dado'd, glued, screwed, and lag bolted. On the ground, it's rock solid. Since my workshop is tight, I need to be able to move it around via retractible casters. As you can see from the picture, I attached a set from Rockler. I will call Rockler on Monday because these aren't working and, I think, are dangerous. I don't believe that I've exceeded the weight they are designed to hold. But in order to retract them, I have to use a pry bar and block to pull up the lift mechanism. This is after I lubed the mating surfaces with a very slick lube, and then lithium grease. Beyond that, individual casters were a bad choice on my part because, since the lathe is deliberately bolted off-center, if I lower the wrong side first, I fear momentum could cause the whole business to topple. Any system needs to lift and lower both legs on an end at once. Does anybody have a recommendation? Thanks, Russ
