I apologize for bumping...just want to share
Resaw? Almost every day. You want a wide blade with a low tpi count. This old WO Navy Yard 4X7 bearer is about to produce some replacement frames:
Basically, I find any fence is a waste of time if the saw and blade are tuned. Any long fence must be adjusted to match the blade track and readjusted with every blade change. Blades track in one direction or the other away from your layout line because their tooth set isn't perfectly matched on both sides of the blade.
I generally fix the blade track and use a chalk or pencil line followed by the thickness planer and have little trouble, tho I don't go thinner than my small planer will handle. I might make myself a point fence if I had a large run of thin stock to get out, however.
One reason I don't like gluing anything but a perfectly-planed surface, besides not liking to be so fussy (and slow) resawing exactly to a mark, is that it takes a whole lot more glue to fill those saw marks. And with a glue that doesn't fill gaps well (which is just about all of them short of thickened epoxy), there may be trouble ahead for that lam.
A hand saw that wanders off track is tuned by lightly removing a tad of set on the side it wants to wander using a carborundum stone.
A bandsaw blade
https://mechanicfaq.com/bandsaws-for-resawing/ is tuned basically the same way. Reset all your guides first by the book to make sure they are set to that particular blade. Instead of stoning the teeth, try stoning the rear corners of the blade first...taking a little sharpness off the rear corner on the side the blade wants to wander may straighten the cut out without touching the teeth.
Set the height adjustment to match the stone and lightly touch it to the blade with the machine running.
Some folks round their new blades off at the back corners as a matter of routine....spose to make them less prone to breakage during a turning movement...on blades set up that way you touch the stone gently to the side of the teeth just like with a hand saw.
