PSI Mighty Micro Saw
Gruntster
Covington, Ga
http://www.pennstateind.com/store/mts3.html
Has anyone ever used this? I would like something to work on more segmenting. I have a 9" and a 14" bandsaw, but just don't seem to get the 'perfect' square cut consistently. This seems like it may be great, especially with the small footprint of the machine. The dinky motor on it is a concern, but I imagine it will do fine for blanks.
Monty
Group Buy Coordinator
Pearland, Texas, USA.
For all intense in purpose, this in the same saw
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42307
From what I've read it is way underpowered and the depth is limited to just over 1/2".
broitblat
Bellevue, WA, USA.
It should be called the Wimpy Micro. I tried one and found it virtually worthless. It was too underpowered to cut through much of anything. Depth of cut was also a limitation. I generally try to give products the benefit of the doubt, but I can't imagine any use for this except maybe for balsa wood that is less than 3/4" thick.
-Barry
leehljp
Member Liaison
Tunica, Mississippi,
Originally posted by broitblat
<br />It should be called the Wimpy Micro. I tried one and found it virtually worthless. It was too underpowered to cut through much of anything. Depth of cut was also a limitation. I generally try to give products the benefit of the doubt, but I can't imagine any use for this except maybe for balsa wood that is less than 3/4" thick.
-Barry
I personally think that is an understatement! I have one and agree. Nice idea, but not nearly enough power for anything but balsa wood.
Texatdurango
Show Low, Arizona
You know, if we could make this post a "sticky" it would save a lot of folks from asking the exact same question and a lot of folks going out and buying this saw only to return it the next day.
Without knowing any better, I too fell victim to this “neat little saw†while at Harbor Freight one day. The first 8 seconds of trying to cut a wood blank told me that it was worthless!
edman2
Local Chapter Leader
Greenbrier, AR. USA.
Monty,
I think this is the HF version:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93211
I have the little cutoff saw and use it to cut pen tubes. For that it does just fine. It probably is too small for anything else.
Monty
Originally posted by edman2
<br />Monty,
Thanks for catching that. That's the one I ment to post. That's what I get for not paying close enough attention.
BruceK
Ocean Park, Washington.
This is what I have:
http://www.byrnesmodelmachines.com/tablesaw.html?id_mm=1222MM484944
This is a real precision saw. I use it in my wooden ship modeling, for cutting planking and framing. It's spendy but it's no toy compared to the others. Highly recommended if you have the $$$$
its_virgil
Wichita Falls, TX, USA.
Both the PSI and HF saw are a waste of $$. I had the HF saw and it would not cut a pen blank. If a really good small table saw is needed, then this is also an excellent choice: &lt;http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=80463&gt;
I know some guys who have this saw and it performs very well.
Do a good turn daily!
Don
Kaspar
Ahead of the curve. Waaay ahead.
Originally posted by BruceK
<br />This is what I have:
I have this one as well. There's nothing better. Even the Proxxon can't touch it. It is a serious machine. The mic head, the extended rip fence and the miter extension are musts.
