Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Reply
Old 05-09-2008, 12:49 AM   #1 (permalink)
Chuck Key's Avatar
Photos: 1
Default Pentel Pencil Conversion Mandrel FAQ
I had a mandrel made about seven years ago to aid in turning Pentel pencil conversions. I have made countless pencils with it to date and will continue. Here is a photo of the mandrel.
It uses two 1/4 x 28 nuts and a slimline size bushing on one end and two 8-32 nuts with a shop made bushing on the other end. Here are additional photos of the mandrel with a blank mounted and another picture of the setup mounted on a lathe.
This setup makes it easy to turn the Pentel pencil conversion.
Chuckie
Last edited by Chuck Key; 03-16-2009 at 10:32 AM. Reason: Change title to include FAQ
Chuck Key is offline   Reply With Quote Top
Old 05-11-2008, 10:11 PM   #2 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #1
My only other question is I've got a step bit per the specs that Don Ward published and as it turns out it is 17/64 instead of 1/4. Do you think a 64th would make any difference?
Answer #1
Look at the first picture above. You will see some blue painters tape wrapped around the mandrel. That is what I use to take up that 1/64th. The tape does make a difference. I usually use two wraps around the mandrel which is about right for my drill.
Old 05-11-2008, 10:20 PM   #3 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #2
What do you mean by SHOP MADE BUSHING?????
Answer #2
I find it helpful to make and use a small step bushing on the business end of the pencil as shown in this picture.
The yellow piece is the shop made step bushing. The RED step is a guide to make a tenon for the pencil nib. Is is cut with a 1/8 inch parting tool (YELLOW X)
The second step BLUE provides a guide line for the start of the outside diameter of the pencil body.
Old 05-11-2008, 10:24 PM   #4 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #3
My question is how the mandrel will be connected on the lathe, especially with the small threaded end.
I'm assuming maybe a sleeve and nut(s) go on the small end; Will the small end go to the headstock with a chuck on the nut?
Answer #3
I hold the mandrel on the threads in either a drill chuck, collet chuck, or usually in the three jaw chuck on my metal lathe. I have been doing this on the same mandrel for over seven years. The threads are worn slightly but they get to where they tolerate the pressure.
Old 05-11-2008, 10:26 PM   #5 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #4
If I have it right so far, the 1/4 end has an indent in the end to accomodate the tailstock?
Answer #4
You are correct. The other end will accept a 60 degree center to hold it in place.
Old 05-12-2008, 12:55 PM   #6 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #5
Always time for questions!
Q. The main body of your mandrel was made from an old "regular" mandrel?
A. Yes, I purchased several new mandrels and are modifying those for the conversion mandrel.
Q. The smaller end, the nib end, is the same as the inside diameter of the pentel mechanism, right?
A. Yes, again. You are correct.
Q. How did you get the 60 degree indent, did you drill it yourself?
A. The 60 degree indent is original to the mandrels I purchased. I do not modify that part at all.
I am planning to attend the NOVA Picnic this weekend. Maybe we can share a few of our secrets in this area :)
Old 05-12-2008, 01:42 PM   #7 (permalink)
Chuck Key's Avatar
Photos: 1
Default
FAQ #6
Nuts? Are you nuts?
Answer #6
You will need to pick up a couple of 1 x 28 tpi nuts if you do not have them. They are available at Lowes in the Special fastener drawers in Drawer section C.
Old 05-18-2008, 10:45 PM   #8 (permalink)
Chuck Key's Avatar
Photos: 1
Default
Quote:
Originally posted by Chuck Key
FAQ #6
Nuts? Are you nuts?
Answer #6
Make that 1/4 x 28 not 1 x 28, duh!
Old 01-09-2009, 01:25 AM   #9 (permalink)
Chuck Key's Avatar
Photos: 1
Default FAQ #7
FAQ #7
Are these mandrels still available?
Answer #7
Yes. The mandrels are still available and will continue to be available until further notice.
Old 03-16-2009, 08:36 PM   #10 (permalink)
George_Clark's Avatar
Photos: 0
Default
John,
I'd like to order another Pentrel mandrel; sending payment via paypal.
George
__________________
George
George_Clark is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
