Oneway Lathe?
yorkie
Charlotte, North Carolina
Last year I bought a Delta variable speed Midi lathe and was thinking of upgrading to a Oneway midi lathe (the 1224 I think).
Is the Oneway worth the crazy money they're asking for it? Is there another lathe out there I hadn't considered before?
How much can I sell my Delta Midi lathe for?
Thanks a lot, guys.
keithkarl2007
Ireland
The Jet 1642 has a bit more capacity both along the length and over the ways. The 1 1/2 HP Jet costs a little less than the Oneway but the Oneway is only 1 HP. For that reason I'd lean towards the Jet. They can't be faulted. I have the 3520B.
Hopkins SC
Which Delta do you have? I do not see this as an upgrade to the Delta 46-460 at all. What are you wanting to do with this lathe..Pens? Bowls? ect?
keithkarl2007
Ireland
This is the 46-460.
Oneway 1224
Jet 1642
keithkarl2007
Ireland
You can slide the headstock right to the end of the ways on the Jet for outboard turning using the optional free standing toolrest or your own fabricated one.
Hopkins SC
Your showing the 46-460 standard...show it decked out....feature wise..stock vs stock...they are very close..I was refering to the HP and features.
keithkarl2007
Ireland
Ok I jsut read that...that is pretty cool..didnt see that on the spec list
No worries. I'm not with it this evening, i didn't realise it was you I was talking to. :biggrin:
Ed McDonnell
Melbourne, FL
Thanks a lot, guys.
Make sure you get a chance to try one before you drop big bucks on one. The resonance from the hollow tube on Oneway lathes drives some people nuts. Other people don't notice it. I also don't like the way the base cabinet gets in the way of my legs for some lathe operations, but that's just me. People who are used to the base cabinet don't seem to mind.
The Jet 1642 can be had with either a 1-1/2 HP or a 2 HP motor for about the same price. Either one would let you do anything you wanted.
You really need to try whatever you plan on buying to make sure you are getting what's right for you.
Ed
Wildman
Jacksonville, NC, USA.
You did not mention whether have room for a full size lathe or voltage requirements. If have 220 volt outlet recommend this one. With few exceptions same as Jet 1642 just check specs. they do go on sale couple of times a year.
Buy Rikon 16" X 42" Heavy Duty Lathe, Model 70-300 at Woodcraft.com
If space and voltage a problem would recommend Nova DVR XP or 1624--44 some assembly required.
Reconditioned Products
Looked long and hard at Oneway 1224 when they first came out much less than now. A very good lathe but like Nova optional accessories really pricey.
walshjp17
Weddington, NC
[quote
Ed[/quote]
True, but the 1 1/2 HP is 110V vs 220/240V for the 2 HP.
flyitfast
San Antonio, TX 78247
I was just making pens (I thought). But the wife treated me to a new Robust Sweet 16. Well, I still make pens, but I have found that I now like to make bowls, platters, too.
You never know. :biggrin:
gordon
Ed McDonnell
Melbourne, FL
All I make are pens. The Delta works perfectly but I just got a big order and thought I would treat myself to an upgrade.
Hi Stephen - If you really want to specialize in pens and don't see yourself getting interested in bowls, boxes, hollow forms and such, here's a thought. Consider getting a metal lathe to use in addition to your current wood lathe. It would open up a whole new universe of pen making techniques.
I never thought I would have much use for a metal lathe until I got one. Now I can't imagine my shop without one. And if you ever do decide to take up other types of woodturning, a metal lathe will allow you to create some really nice embellishments for your woodturnings.
Not trying to complicate your decision. Just thought it was worth mentioning.
Ed
yorkie
I like the midi lathes in variable speeds but wish Powermatic would make one of a higher quality. I like the Delta's reverse but the belted variable speed bugs me.
I guess my ideal would be a Powermatic or similar, reverse speed 0-4500 rpms without having to move a belt.
I like quality stuff.
Dick Mahany
Palm Springs, CA
I have had the Jet 1642 for nearly 10 years. I like it very much. I have turned many things on it and oddly enough, just started making pens!! Variable speed and reverse have been great for pen turningm finish sanding and CA application. I use it exclusively to turn, drill, end-square, sand, finish, polish and couldn't recommend it highly enough.
When I first started, I said "I'll only turn bowls" :) Then came spindles, hollow forms, Christmas ornaments, scoops..............and now.............pens :biggrin::biggrin:! The lathe came with a Oneway-type live center and I don't think I'll ever outgrow it.
I have made many mods and improvements such as tail stock tilt away, vacuum system, lighting and dust collection modifications and you can see them here if you want to take a look: https://picasaweb.google.com/dmshopshots
Best of luck with what ever you decide !
greggas
North Easton, MA
A couple years ago I was looking to upgrade to a full size lathe and always had my eye on a OneWay. As I did more research I came to the conclusion that the Powermatic 3520B was the better choice for me. It offered all of the same features had comparable HP options and was priced significantly less which was nice with three kids in college ( who am I kidding...it just left more moolah to buy other shop toys with) I have been tremendously happy with my selection.
Good luck
ossaguy
San Diego
Wow,a real treat to look at all of your projects! Especially like your beautiful jewelry boxes.
Nice work!!!
Steve
walshjp17
Weddington, NC
Your 1642 mods are just ... WOW! Most of the features (and then some) of the Powermatic 4224 without the Powermatic price. Wish I had the manufacturing skills you have to make those mods to my 1642.
raar25
Glastonbury CT
Why does it seem like no one considers the Grizzley lathes? I have been on the fence for a while and they appear to be priced very well for the features. Any thoughts?
hilltopper46
East Troy, Wisconsin, USA.
I have a Grizzly 12x20 benchtop lathe. It needs its third on/off switch installed. The on/off switch is difficult to install. The speed readout doesn't work. The precision of the tailstock ain't that great. And so on.
