Nova Comet II - older model???
Drcal
Tampa, Florida
I had the opportunity to buy a Nova Comet II Midi Lathe. The lathe itself is BRAND NEW in a sealed box but it is not the newest model. It is the 46000 and not the 46300.
I bought it because it the price was GREAT! I still have not removed it from the box because after reading reviews, I am having second thoughts. Many complain of loud noise when the lathe is running and of weak power when turning thick spindles.
I want it as a dedicated lathe that I can sit at so I will put it on a custom short stand. I want it mostly for peppermills which means I would be turning from a 3 inch spindle blank. It has a 3/4 HP motor.
The only visible differences between the older and newer models are :
  • a different motor cover
  • different on/off switches
  • a little sturdier cover for belt pulley housing
Should I spring for over $250 more and buy the newer model?
Should I forget Nova and pay even bigger bucks for something else?
Does anyone have the older Nova Comet 46000???
(I do have a perfectly good Delta midi that I am keeping for stand up turning. This would be my second lathe and I don't want to spend a fortune.)
I have been looking for a used small lathe in the Tampa area for over a year--no luck.
Carmen
longbeard
West Virginia
I would. i've had mine for about 3 months now and love it. The instructions tell you to let it run before use to break in the motor.
Harry
Claremont NH
I used mine for a few years and it was great. I did let mine run to break in as the instructions said. I do seem to remember that there was some trouble with the first ones that came out but I am not sure what that was..
Fibonacci
Ridgecrest, CA
I bought the new one (46300) in Feb.
After 3 sets of replacement motors and one full replacement lathe, I called them this morning and am getting a refund under threat of a lawsuit. A lot of people have good things to say about them, but with a 4 week turnaround time on parts and getting shipped one that was obviously DOA before I even took it out of the box, I decided I was done screwing around with it.
I am trying to decide whether to spend more to upgrade to a Jet or spend less and get one from Harbor Freight that I know will have issues. Either way, I won't be returning to Teknatool for powered things.
That said, I absolutely loved the G3 chuck. I had used the Penn State Utility Chuck and the Barracuda before and the G3 just blew both of them away. I would buy another chuck from them in a heartbeat.
preacherman
Crossville, TN 38572
I have the older version. I also found it used and hardly used at that. The guy I bought mine from said he only turned on pen with it. It was then placed back in the box. I have had no problems from the lathe. If I were looking for another one a nova comet would be at the top of my list.
As far as power goes I have never had any problems as I mostly turn pens. I am currently working on a vase that is max capacity for the lathe. It does seem to struggle just a little bit with so much weight. But this vase is 9 inches in diameter and 13 inches tall made from maple and cherry. I think this piece would be a load for any lathe in this category. One reason I am making this vase is to test the limits of this lathe. So far I am extremely pleased.
If you got a good deal on the lathe I would keep
It and enjoy it. I see no need in being concerned about the few negative reviews.
TDE
Tuckerman Ar.
I have the older version also. I did have a problem with mine surging in speed. They sent me a new motor and speed control and it was damaged in transit. They sent me another motor and speed control and it surged as soon as I turned it on. The third set then has worked well for about three months so far. My lathe was 11 months old when I had my first trouble with it. I hope this one doesn't work for 11 months then mess up also. I like everything about the lathe except the tailstock has to be tightened like a bolt instead of a camlock like most have. If I got one at a bargain I would sure use it. Good luck. Ted:)
