NOVA 46 300
corks58
Wasilla Ak.
I just ordered another lathe and Rick Herrell said he doesn't have the specs to make me new tool rests
Does anyone know the tool rest specs for the Nova 46 300?
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
I believe that lathe is more commonly known as the Comet II
You might check with Rick to see if he has the specs under that name rather than the SKU number.
If not, I suggest that you wait until you receive it & measure the stock to rest to be sure you get the exact dimensions that he needs.
lorbay
BC. Canada
Here you go.
Lin
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
I think Rick might want the post length also which is not given in the spec sheet.
indytruks138
Sachse, TX
Just as an FYI read my post about this lathe tripping my GFI. Let me know if you have the same issue if you try and run this off a GFI outlet.
