The wife put the ABSOLUTELY not on that. You see the pic of my old work area, I'll be quite happy for quite some time. Plenty of room behind for an addition, just maxed out the building fund right now.I think you might want to up your dedicated workshop area. You will over run it in no time and there is nor reason to waste space on something that can be parked outside. I have found no matter how big your shop is you will collect more stuff than you can fit in it.
Mike
what type of construction? frame or block? I dont see any pipes, so no plumbing? Are you going to do an under ground electrical feed?
Mike
For that reason I wanted plumbing and climate control but it was not in the budget.At this rate you will be moving into your new shop soon.
hopefully by sept 1 i should have it up, wired and insulated.12 x 28 is awesome - when do you expect it to be "move-in" ready?
Wellllllllll...................:biggrin::biggrin:I take it you poured your side of the shop first.
Wire mesh? fibre fil? I take it you used 3000psi, what does a yard of mud go for in your area of the woods?
Wet for 7 days I can handle:wink:, but I had better see wood on the floor before ant dang month is up.Rain is good for the curing of the slab, you should keep it soaked for the first seven days and keep wetting it for a month. Reduces cracking. And those namby pamby carpenters can just get their butts up there and get those walls up. You do have lights dont you. Mike
