Progress is being made on the alignment
We need more information to know exactly what is happening.
However, all mandrels will flex. Minimize the flex by using a 'pro' type mandrel. Shorten and turn only one half of the pen at a time.
For larger (non-7mm) pens, use the 'no mandrel' turning methods. Makes a world of difference.
I have spent several hours taking all these suggestions and working each one at a time. I have found the headstock has some movement horizontally. There is a clip ring that should be holding the shaft in position but there is no groove for the ring. I have located a locking collar and ordered it which should solve the problem.
Next, I found the shaft is very close to tolerance when it is held in position. But, when I put the adapter to change the shaft from a 3/4-10 TPI to 1-8 TPI, I pick up a total run-out of another .007" - .008". That seems to add up to the total mis-alignment. It must have been there from the beginning. I wonder now if I can get PSI to exchange the adapter.
With the adapter and mandrel removed, I can put the center back on and pull the tail-stock up to the headstock. I can't see any noticeable alignment problem. I am having problems finding a way to measure the difference because the headstock center is made from hex material.
Like you said, all the mandrels have some run-out. I suspect this is probably true. I pulled everything up as tight as I could without the collar and I still see run-out but it seems to be greatly reduced. I am hoping that adding the collar will close the gap. Or, at least close enough to where I can make enough pens to sell so I can afford to buy a better lathe. :doctor: Guys, I am disabled and on SS disability. This makes funds a little small for hobbies. The wife says I can only buy another lathe if I sell enough pens to buy it. :frown: That sounds reasonable.
As Randy mentioned, the bearings may be worn as well. And yes Randy, the link you provided is very close to the model that I have. Mine is model number S36066 which does not show up now. The manufacture date is 081501 which I would say was August 15, 2001. The lathe doesn't show much wear from what I can tell. The serial number and manufacture date are printed on paper labels and they are still clear and intact. There are very few scratches on the lathe overall. But, all in all it is still a cheap lathe as mentioned in the title.
Frank, can you point me in the right direction to explain what you are referring to as a 'pro' type mandrel?
All of you have been a great help and I appreciate each and every comment and suggestion. I really mean that!
Larry
