| Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
Hi all. Just got my lathe and now I need all the other tools. I know there are a few places to get things like mandrels and barrel trimmers and presses,.... etc from but what I'd like to know is...
is there one place that has better quality ? PSI has a kit for $86 with mandrel, trimmer, 5 pen kits, 5 pencil kits, pre-drilled blanks, glue, shellawax,... and 3 crappy chisels. Is this a good deal? I plan to get their (PSI) 3 piece CARBIDE chisels ($47) and pen press ($39.95). Is PSI ok or should I look elsewhere? Money is tight. All constuctive comments appreciated. Thanks |
#2 (permalink) |
Before you spend more money on carbide tools. Try turning with the tools that come in the kit. You called them crappy, but they actually work well. I have ordered some chisels from them and found them to be very good. They sharpen well and I have turned many items with them. I buy used tools at garage sales, flea markets and they are good to grind into shapes that you want as you learn more and try different ways to turn different items. If you are not sure that you want to do this you should spend the least amount of money and try it out.
__________________
Cindy
San Francisco, CA "All the strength you need to achieve anything is within you" |
#3 (permalink) |
IMHO you don't need carbide chisels. If you go that route keep in mind that you can't sharpen carbide with a regular grinder, so add ANOTHER expensive tool to that list!
Don't buy the sales pitch that carbide never needs sharpening, it ain't true! Carbide "chips" and that's even worse than getting dull. If you only pay $47 for THREE carbide chisels then trust me, they're CRAPPY too!
__________________
Rick Herrell
Pilot Mtn.,NC ![]() "The pain of using a cheap tool lingers long after the joy of saving money has passed" Last edited by rherrell; 02-14-2012 at 05:45 AM. |
#4 (permalink) |
Rick's post reminds me.
From what I've read, you bought the HF lathe. I have that same one, and can tell you that you'll be wanting another tool rest for it. The one that comes with it is too long to do pens one barrel at a time, and the metal is so soft that it gets all kinds of nick in it, making turning more difficult. I keep meaning to bring mine home for measurement so I can order one of Rick's. I've used one of his before, and they are well worth the money. |
#5 (permalink) | |||
Quote:
Quote:
Quote:
Yes you should shop around. Check Wood-N-Whimsies | Page 1 of 1 Pen Making - Woodturners Catalog - Woodworking tools and supplies specializing in woodturning. Pen Kits - WoodTurningz Bear Tooth Woods - Pen Kits Pen Making Kits | Pen Turning Supplies | Wooden Pen Blanks http://www.exoticblanks.com/ Indy~Pen~Dance and others. Your welcome! And you might also check out threads for new turners. They get into a bunch of this info too.
__________________
"Grow, grow where you are, anchor your roots underneath. Doubt your doubts, and believe your beliefs"
Delrin Bushings and Sleeves For Many Popular Kits http://www.pensbyhans.com/Bushings.html |
#6 (permalink) |
This thread is in 2 places
Mandrels, trimmers, and other stuff Read that thread as well, most of the comments are the same. Do your research and purchase quality tools wisely. Also keep in mind it takes many years to establish a collection of quality tools (unless you have a ton of money). |
#7 (permalink) |
Photos:
I used to use barrel trimmers but found them a little unwieldy. On a tip I started using a 3/4" Forstner bit instead and have been very happy with it. The only caveat is that you'd probably want to use a pen drilling jig that keeps the piece at a perfect 90 degrees to make up for the fact that a Forstner bit doesn't have a sleeve attachment to guide it to the piece at a right angle. Now I don't have to buy additional barrel trimmer attachments each time I add a new pen style to my arsenal, nor do I have to awkwardly hone the tiny blades on the barrel trimmer.
__________________
Andrew L. Heck
#8 (permalink) |
Photos:
Xander Where in Arizona you from? I am up North. I would not buy a pen press I use my lathe I have some sugar maple scraps I formed to fit my chuck and tail and use the tail stock screw to push the parts togeather. Just my 2 cents /william
__________________
![]() Broken Chain Forge and Woodworking Isaiah 58:6 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
